HyperWorks
HyperWorks
2023.1
  1. Home
  2. Model Build and Assembly
  3. RBE2s, RBE3s, and MPCs
    Create, review, and edit RBE2/RBE3 elements and MPC equations.
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Manage Files and Data
  • Sessions and Report Templates
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Meshing and Elements
  • Model Build and Assembly
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • Squeak and Rattle Director
  • PhysicsAI
  • Results Data
  • Plot Data
  • Multibody Modeling
  • Media Files
  • Tabulate Results
  • Text Files
  • Publishing and Reporting
  • Collaboration Tools
Index
HyperWorks
HyperWorks
  • What's New
    View new features for Altair HyperWorks 2023.1.
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
    • Manage Parts
    • Manage Subsystems
    • PostgreSQL Installation and Configuration
      Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
    • Section Library
      Use the automotive section library for rapid concept development in the early phases of the vehicle design process.
    • Organize Entities
      Use the Organize tool to move or copy entities into their proper destinations.
    • Match Parts
      Automatically group selected parts into part sets based on comparison method and criteria selected.
    • Classify Parts
      Set up and use machine learning (ML) models to automatically classify parts under user-defined labels and into part sets.
    • Renumber Entities
      Use the Renumber tool to review and organize the IDs of model entities.
    • Reorder Entities
      Change the order of named entities in database.
    • ID-Management
      Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
    • Perform Representation Operations
      Use the Reps tool to perform representation operations for parts and subsystems.
    • Manage Scenarios
      Scenarios are a mechanism to apply controls to engineering entities.
    • Mechanism Browser
      Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
    • Model Verification
    • Systems
      Local coordinate systems can be used for setting up loads/boundary conditions that do not act in the global axis direction, transforming results, defining material orientation, and many other operations.
    • Create Vectors
      Define vectors in 3D space.
    • Assign Properties and Materials
      Define physical and mathematical characteristics of parts.
    • Generate Contacts Automatically
      Use the Auto Contacts tool to determine contact interfaces between selections of components or elements. Based on the user-specified options like proximity tolerance, surface creation method, main surface type, and secondary type, the tool generates contacts based on set segments or node and element combinations.
    • RBE2s, RBE3s, and MPCs
      • Create, Review, and Edit RBE2 Elements
      • Create, Review, and Edit RBE3 Elements
      • Create, Review, and Edit MPC Equations
    • Create and Edit Curves
      Use the curve editor to create and plot XY curves.
    • Analytical Rigid Surfaces
      The Abaqus solver offers the flexibility of modeling rigids as surfaces using primitive geometry.
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
HyperWorks
HyperWorks
2023.1
  1. Home
  2. ...
  • What's New
  • Get Started
  • Tutorials
  • Tool Finder
  • Browsers
  • Sketching
  • Topology
  • FE Geometry
  • Composites
  • Connectors
  • Morph
  • Skeleton Modeling
  • Design Space
  • Optimization
  • Design Explorer
  • Validate
  • Analyze
  • Axisymmetry
  • Concept Modeling
  • Crash and Safety
  • Airbag
  • Aerospace
  • Aeroelasticity
  • Certification
  • PhysicsAI
  • Results Data
  • Plot Data
  • Media Files
  • Tabulate Results
  • Text Files
Index
ON THIS PAGE
    ON THIS PAGE
