Meshing
Enhancements
- Component Geometry Organization
- The Create in preference option has been added in the Geometry section of Preferences to organize newly created surfaces/solids. This option has been removed from geometry tools like Ruled, Extrude/Revolve, Patch/Spline, Skin, and Offset.
- Detach
- Time has been reduced.
- Alight/Project > Plane
- Improvements have been made in performance and tool simplification.
- Criteria File
- Report generation for criteria file checks is now available.
Resolved Issues
- Midmesh: - Automatic: "defeature openings width" has been made a factor similar to other midmesh parameters.
- Parts selection for Midmesh extraction is now available.
- Repair/Fill: feature angle definition has been added to retain edges on filling face.
- Inspect: press ESC twice to exit the tool.
- Align: the guide video has been updated.
- Midmesh functionality has been improved via BM.
- Face Edit:- Face Edit functionality has been improved.
- FE Geometry:- Performance has been improved when FE geometry is used.
- Free Form Mesh:- Performance improvements have been made in the Free Form Mesh tool.
- Transparency mode has been turned off.
- Anchor nodes are no longer restored when exiting the panel.
- A warning message is provided for excessive amounts of edges.
- Detach:- Performance improvements have been made in the guide bar.
- Parameters editor:- Improvements have been made with radius selection on holes and fillets.
- Imprint:- The guide structure is now adjusted to be more logical.
- Midsurface:- Performance improvements have been made.
- Edit elements:- Performance improvements have been made in Split > Combine and error message appears on incorrect elements selection.
- Performance improvements have been made in Move.
- Cut Hole:- Performance improvements have been made.
