Create and Edit Joint Legs
Use the Joint Legs tool to add, delete, and move joint leg ends around the face of a bounding box.
Align Joints
Use the Align tool to align joints to an anchor.
Figure 4. Original mode, two joints misaligned
Figure 5. Select the joint to move and define direction
Figure 6. Joint is aligned
