Absorb Members
Use the Absorb tool to reverse engineer a skeleton model using lines or 1D elements as input.
View new features for Altair HyperWorks 2023.1.
Use the Skeleton Browser to manage and run skeleton entities.
Use the Joint Box tool to define junctions in your skeleton model.
Use the Joint Legs tool to add, delete, and move joint leg ends around the face of a bounding box.
Use the Symmetry tool to reflect and map joints and members using a plane.
Use the Members tool to create members between two joints.
Use the Member Panels tool to connect three or more members.
If a panel or member has been created or edited, it may be necessary to connect or reconnect it.
Use the Equivalence tool to consolidate overlapping joints within a given tolerance.
Use the Combine tool to merge continuous members.
Use the Duplicates tool to erase members that share the same start and end joint.
ON THIS PAGE
ON THIS PAGE
