Define Surface Plots
In this tutorial, you will learn how to create surface plots.
The Define panel enables you to create new Surface plots. New data can be mathematically defined using the program's curve calculator, or entered as values.
View new features for Altair HyperWorks 2023.1.
Learn how to access and download required model files.
In this tutorial, you will create and edit curves and plots.
In this tutorial, you will learn how to create bar charts by entering values, importing a data file, or specifying a mathematical expression.
In this tutorial, you will learn how to create complex plots from a data file and add and edit complex data curves by using mathematical functions.
In this tutorial, you will learn how to create polar plots from a data file and add polar plots by using mathematical functions.
In this tutorial, you will learn how to customize the program using the preference file.
In this tutorial, you will learn how to work with the Axes panel, edit curve attributes, contour line plots, and use the Edit Legend dialog.
In this tutorial, you will learn how to query data from the surface plot and create and use datum planes.
