Dampings
Damping models are used to associate damping properties with an element. The damping models in SEAM can be used for many complex applications.
Figure 2. Create Damping Entity Editor
- Name
- Enter a unique name.
- ID
- Enter a unique ID.
- Damping Type
- A predefined type which describes the general form of the damping. The
damping type is chosen from the Config drop-down menu.Note: The damping type determines the damping parameters.
- Parameters
- Use the parameter fields to enter the data for the damping model. The
parameter fields that are displayed depend on the damping type
selected:
- Structural Damping parameters
- Acoustic Damping parameters
