Dynamically Linked Library (DLL) or Shared Object (SO)
MotionSolve supports two separate levels of user DLLs/SOs and the algorithm attempts to resolve the symbols, starting from the most specific library. It is possible to specify an Element Level DLL/SO (most specific) and a Machine Level DLL/SO.
- Element level - Specify the name of the DLL/SO in the element definition.
For example:
<Constraint_Coupler id = "1" label = "TwoJoint" joint1_id = "30603030" joint2_id = "30602031" freedom_1 = "T" freedom_2 = "T" usrsub_param_string = "USER(-8.5)" usrsub_dll_name = "C:/work/testsub.dll" usrsub_fnc_name = "coupler_function" > </Constraint_Coupler>
- Machine-level DLL/SO
You can create an environment variable called MS_USERSUBDLL and set it to the DLL/SO file. This environment variable is not defined automatically when MotionSolve is installed. However, Fortran and C/C++ DLLs/SOs are provided in the installation in folder <install-path>\hwsolvers\usersub\subdll\<platform>. This is so you can run some of the test models that use user subroutine DLLs.
The selection of what DLL/SO is loaded and used is based on the "most specific" rule: number one overrides number two.
