Computes the square of the difference between a function’s value at a certain time
        and a desired value.
            Assume that you wish to determine the design of a suspension such that the camber
                angle of each wheel is 2° at assembly (T=0). Here is how you would instantiate the
                camber response at T=0 for each
                wheel.
>>> # Left wheel (LW) camber response
>>> camberL = ValueAtTime (
       label         = "LW Camber @ T=0",
       measuredValue =  “Camber (22,11)*RTOD”,
       atTime        = 0.0,
       delta         = 0.1,
>>> camberLDev  = DeviationSquared (
       label       = "LW Camber Deviation @ T=0",
       signal      =  camberL,
       targetValue = 2.0
>>> # Right wheel (RW) camber response
>>> camberR = ValueAtTime (
       label   = "RW Camber @ T=0",
       measuredValue =  “Camber (223,11)*RTOD”,
       atTime        = 0.0,
       delta         = 0.1,
       label       = "RW Camber Deviation @ T=0",
       signal      =  camberR,
       targetValue = 2.0,
The calculations in DeviationSquared are implemented as follows:
(1)
