MotionSolve
MotionSolve
2023.1
  1. Home
  2. Tutorials
    Discover MotionSolve functionality with interactive tutorials.
  3. Using the MotionSolve API
  4. MV-9002: Slotted Link Tutorial
    In this tutorial, you will learn how to import geometry and build a Poisson Contact using the msolve MotionSolve Python API.
  • What's New
  • Overview
  • Tutorials
  • MotionSolve User Guide
  • MotionSolve Reference Guide
Index
MotionSolve
MotionSolve
  • What's New
    View new features for MotionSolve 2023.1.
  • Overview
    MotionSolve® is an integrated solution to analyze, evaluate, and optimize the performance of multibody systems.
  • Tutorials
    • Access the Model Files
      Learn how to access and download required model files.
    • Introduction
    • Rigid Body Dynamics
    • Model Definition Language
    • Flexible Body Dynamics
    • Advanced Simulation
    • Optimization-DOE-Stochastics
    • Durability - Fatigue
    • Automation
    • User Subroutines
    • Co-Simulation
    • Vehicle Simulation using MotionView
    • Using the MotionSolve API
      • MV-9000: Bouncing Ball Tutorial
        In this tutorial, you will learn how to model a simple 1 DOF mechanism using the Msolve Python API.
      • MV-9001: Simple Pendulum Tutorial
        In this tutorial, you will learn how to model a simple 1 DOF mechanism using the Msolve MotionSolve Python API.
      • MV-9002: Slotted Link Tutorial
      • MV-9003: LuGre Friction Tutorial
        In this tutorial, you will learn how to implement and use a new MotionSolve object.
    MotionSolve is a system level, multibody solver that is based on the principles of mechanics.
    This manual provides a detailed list and usage information regarding command statements, model statements, functions and the Subroutine Interface available in MotionSolve.
MotionSolve
MotionSolve
2023.1
  1. Home
  2. ...
    • Tutorials
  3. MV-9002: Slotted Link Tutorial
  • What's New
  • Overview
  • Tutorials
Index
ON THIS PAGE
  • Load the Msolve Module
  • Create a Model
  • Add Units and Gravity
  • Add Parts
  • Define Markers for Geometry
  • Import Geometry
  • Add Joints
  • Add Motion
  • Add Contact
  • Create Requests
  • Run the Simulation
  • Generate a Plot and Animation
If you are running this tutorial as IPython notebook, you can interactively execute each code cell by clicking SHIFT-ENTER. The output of the Python code (if any) is displayed and the execution jumps to the next cell. If you want to run it, you also need to make sure that the file slotted_link.fem is in the folder.
Load the msolve module, which is done by issuing this command:
In [1]: from msolve import*
The above command requires the msolve module to be in your computer path. Assuming the above is successful, you have now imported the msolve names into the current namespace. This means that you have access to all the classes and functions defined in msolve and you can start creating the bouncing ball case.
Create a Model
To create the pendulum mechanism, you must first create a model. A model is nothing but a container that serves as a parent for all of the entities.
Issue this command:
In [2]: model = Model()
After creating a model, you can add details, units, and other entities, such as gravity and ground. Most entities have default properties. For example, you only change the length unit from 'METER' to 'MILLIMETER'; everything else is in SI units.
  1. Issue this command:
    In [3]: units = Units(length ="MILLIMETER")
  2. Similarly you can create the gravitational acceleration field. Notice that the gravity is set to zero: it would not affect the motion of the slotted slider.
    In [4]: gravity = Accgrav()
  3. You can now create the ground part. To do that, use the Part class and specifying the ground Boolean attribute as 'True'.
    In [5]: ground = Part(ground=True)
Add Parts
Next, you can create four parts representing the link, cam, pin, and slotted link. You can also specify the mass, initial property, and the center of mass for the part. This information would not be imported to MotionSolve from CAD or FEM file automatically.
Issue this command:
In [6]: link = Part(cm=Marker(),mass = 0.0526,ip=[20.0844,21.7819,1.9169,0,0,0])
link.cm.qp = [0, -17.499994784, 33.609856169]
pin = Part(cm=Marker(),mass = 0.0972, ip = [15.3742, 4.8085, 15.37, 0,0,0])
pin.cm.qp = [0,-0.000001527,74.999999124]
cam = Part(cm=Marker(),mass = 1.2159, ip = [372.14,961.3416,913.45,0,0,0])
cam.cm.qp = [0,0,-21.22]
slotted_link = Part(cm=Marker(),mass = 5.8943,ip = [3721.7065,1.8e5,1.7689e5,0,0,0])
slotted_link.cm.qp = [224.988, 0, -63.813495]
Before importing the geometry, you need to define the marker on the part that the geometry is linked to. You cannot use cm marker in this case; the position of nodes in the FEM is measured in the global reference frame while the cm marker represents a local reference for the part. So, you need to create four markers that coincide with global origin.
Issue this command:
In [7]: link_geo_marker = Marker(part = link)
pin_geo_marker = Marker(part = pin)
cam_geo_marker = Marker(part = cam)
slotted_link_geo_marker = Marker(part = slotted_link)
Import Geometry
Now you can import geometry for the part. To do so, create four external instances. The class External is created to help users import a CAD file or an FEM file. If the file imported has multiple components, you can extract them one-by-one by specifying the 'element' property. When the CAD file is imported, you can improve the mesh by increasing the value of 'refinement_level'. The example below shows how external instances are created in this case:
Issue this command:
In [8]: link_geo = External(rm = link_geo_marker, file ="slotted_link.fem",
                    element=["Link"], refinement_level = 0)
pin_geo  = External(rm = pin_geo_marker,  file ="slotted_link.fem",
                    element=["Pin"], refinement_level = 0)
cam_geo  = External(rm = cam_geo_marker, file ="slotted_link.fem",
                    element=["Cam"], refinement_level = 0)
slotted_link_geo = External(rm = slotted_link_geo_marker, file ="slotted_link.fem",
                    element=["Slotted_Link"], refinement_level = 0)
Add Joints
The next step is to create the joints between different parts. Two fixed joints are created: one between the pin and the link, and the other connecting the link and the cam. For a fixed joint, the i marker and j marker should be coincident with their x,y,z axis aligned.
  1. Issue the command:
    In [9]: ##  Pin-Link-Fix at Pin cm
    pin_link_i = pin.cm
    pin_link_j = Marker(part = link, qp = pin.cm.qp)
    pin_link_fix = Joint(type="FIXED", i = pin_link_i, j = pin_link_j)
    ##  Link-Cam-Fix at Link cm
    link_cam_i = link.cm
    link_cam_j = Marker(part = cam, qp = link.cm.qp)
    link_cam_fix = Joint(
    type ="FIXED", i = link_cam_i, j = link_cam_j)
  2. The slotted link is only allowed to slide along global x-axis. Here, create a translational joint:
    In [10]: ##  Slotted-link-slider-Translational at slotted link cm
    marker_qp = slotted_link.cm.qp
    marker_xp = marker_qp + [0,0,1]
    marker_zp = marker_qp + [1,0,0]
    slotted_slider_i = Marker(part = slotted_link, qp = marker_qp, xp = marker_xp, zp = marker_zp)
    slotted_slider_j = Marker(part = ground, qp = marker_qp, xp = marker_xp, zp = marker_zp)
    slotted_slider_trans = Joint(type="TRANSLATIONAL", i = slotted_slider_i, j = slotted_slider_j)
  3. You can impose a revolute motion on the pin-cam-link entity. To do so, you first need to create a revolute joint that rotates along the global y axis.
    In [11]: ##  Cam-pivot-Revolute at global_origin
    cam_pivot_i = Marker(part = cam, xp=[1,0,0], zp=[0,1,0])
    cam_pivot_j = Marker(part = ground, xp=[1,0,0], zp=[0,1,0])
    cam_pivot_revolute = Joint(type="REVOLUTE", i = cam_pivot_i, j = cam_pivot_j)
Add Motion
The motion can be created by creating an instance of Motion in msolve. You can change the pattern of motion by specifying the property 'function'. The property 'function' should be a MotionSolve expression.
Issue the command:
In [12]: cam_pivot_motion = Motion(joint=cam_pivot_revolute, jtype="ROTATION",dtype=
"DISPLACEMENT",function='360d*TIME')
Add Contact
The last step is to create contact between the geometries that you imported. Two Poisson contacts are created here: one between the cam and slotted link, and the other between pin and slotted link.
Issue the command:
In [13]: cam_slotted_contact = Contact(igeom=cam_geo,jgeom=slotted_link_geo,type="POISSON",
                             restitution_coefficient=0.5,penalty=1e5)
pin_slotted_contact = Contact(igeom=pin_geo,jgeom=slotted_link_geo,type="POISSON",
Create Requests
Before running the model, create requests that track the contact force and the penetration depth. The result can be plotted using pyplot.
Issue the command:
In [14]:#forceRequest = Request(f2="FX({I})".format(I=slotted_link_geo_marker.id))
forceRequest = Request(f1="CONTACT({ID},{JFLAG},{COMP},{RM})".format(ID=cam_slotted_contact.id,
                        JFLAG=1,COMP=1,RM=0),
                       f2="CONTACT({ID},{JFLAG},{COMP},{RM})".format(ID=pin_slotted_contact.id,
                        JFLAG=1,COMP=1,RM=0))
depthRequest = Request(f1="CONTACT({ID},{INDEX},{RM})".format(ID=cam_slotted_contact.id,
                        INDEX=1,RM=0),
                       f2="CONTACT({ID},{INDEX},{RM})".format(ID=pin_slotted_contact.id,
                        INDEX=1,RM=0))
Run the Simulation
At this point you are ready to run a transient analysis. The simulate method is invoked on the MBS model. A validation process is performed on each of the entities that make up the model. This is a necessary step to ensure that only correct models are being simulated. Note that the simulate command can be invoked with an optional flag, returnResults, set to True. This stores the results of the simulation into a run container for further post-processing, as shown below.
You can also generate an output file that can be imported into MotionView for animation.
Issue the following command:
In [15]: run=model.simulate(type="DYNAMIC", returnResults=True,
end=3, steps = 3000)
model.generateOutput()
%matplotlib inline
force = run.getObject(forceRequest)
depth = run.getObject(depthRequest)
from matplotlib import pyplot
pyplot.subplot(2,1,1)
pyplot.plot(force.times, force.get
Component(0),'r',force.times, force.getComponent(1))
pyplot.title("Contact Force Magnitude")
pyplot.xlabel("Time(s)")
pyplot.ylabel("Contact Force (N)")
pyplot.grid(True)
pyplot.legend(["Cam-Slotted Contact","Pin-Slotted Contact"],loc="upper left",prop={'size':8})
pyplot.subplot(2,1,2)
pyplot.plot(depth.times, depth.getComponent(0),'r',depth.times, depth.getComponent(1))
pyplot.title("Maximum Penetration Depth")
pyplot.ylabel("Penetration Depth (m)")
pyplot.grid(True)
pyplot.subplots_adjust(hspace=0.5)
pyplot.show()
You can import the H3D file generated by this tutorial into MotionView for post-processing. The animation below illustrates the motion of the slotted link when the cam rotates.
ON THIS PAGE
  • Create a Model
  • Add Parts
  • Import Geometry
  • Add Joints
  • Add Motion
  • Add Contact
  • Create Requests
