NLDEBUG, NLP2NLC
I/O Options and Subcase Information Entry This parameter converts an NLPARM-based setup to an NLCTRL-based setup in a nonlinear model.
Parameter | Description |
NLP2NLC | Setting this parameter
When NLPARM (and additionally
NLADAPT, if any) entries are defined in
nonlinear models, they are converted internally to
NLCTRL.
- This parameter can only be specified in the global subcase section (above all the subcases).
- This parameter does not require a value to be specified.
- This conversion is conducted after ECHO; if the input deck is echoed out with the ECHO command, the original NLPARM (and optional NLADAPT)-based setup is echoed out.
