Engine Keyword Describes the output of .abf
        files. (.abf [binary] files are optimized for fast plotting of very
        large data sets and is intended for creating 2D and 3D plots using HyperGraph and HyperGraph
        3D).
/ABF
Definition
                            | Field |
                            Contents |
                            SI Unit Example |
                            Time frequency to write
                                data on plot file .abf file. |
                                    .abf file.
                                        - = 0
                                        - An .abf file will be written only
                                            at the end of the calculation.
                - A Runname_run#.tmp
                    buffering file containing the Time History information is written with frequency
                         and translated to an .abf
                    file with the
                         frequency.
                - The reading of an
                        .abf files output by Radioss is only available with HyperGraph 11.0 SA-101 or
                    higher.
                - Translation of the
                        .tmp file to the .abf file
                    executes an external program abf_converter_platform which
                    is provided with the Altair HyperWorks installation at the same
                    location as the Radioss executables.
                - It is recommended to not set the update
                    of .abf files to a high frequency, in case of parallel
                    computation, because it could reduce Radioss
                    performance.
                - In case of a not NORMAL TERMINATION,
                    the .abf file may be incomplete.
                - It is possible to translate a
                        .tmp file output by Radioss
                    to an .abf file at any time during the Engine execution or
                    in case of a not NORMAL TERMINATION, use the
abf_converter_platform program,
                            as:abf_converter_platform -exe
                        Runname_run#.tmp
Example:
[user@machine]$ abf_converter_linux64 -exe test.tmp
.tmp TO ABF CONVERTOR
FILE = test.tmp
OUTPUT FILE = test.tmp.abf
** CONVERSION COMPLETED
                - Platform may be linux32, linux64,
                    linuxia64, macosx64, solarisx64, win32, or win64, depending on the machine
                    architecture.
