/TFILE
Engine Keyword Defines the frequency of writing the time history file of T-file "RunnameTnn".
/TFILE/Type
Definition
| Type | No value: Built-in
                                    format of current Radioss version.
| Time frequency to write data on history plot file T-file. |
- Recommended options are default (no value) or four, which can be read by HyperGraph.
 - This file contains the global results (energy, global mass, momentum) and all the time history requests defined with the keyword /TH/….
 - Additional time history file can be generated with the keywords /ATFILE to /ITFILE for the specific requests defined using the keywords /ATH to /ITH.
 - See "File Extensions and Formats" for details on T-file name.
