*DEFINE_COORDINATE_NODES
LS-DYNA Input Interface KeywordDefines a nodal based moving coordinate system.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DEFINE_COORDINATE_NODES | |||||||
| CID | N1 | N2 | N3 | Iflag | DIR | ||
Definition
| CID | Coordinate system identifier. (Integer)  |
| N1, N2, N3 | Node ID which define the coordinate
                                    system. (Integer)  |
| DIR | Defines the N1-N2
                                    Direction:
 (Text)  |
| Iflag |
 (Integer)  |
