/EOS/TILLOTSON
Block Format Keyword Describes the Tillotson equation of state.
/EOS/TILLOTSON/mat_ID/unit_ID
eos_title
C1 C2 a b
ER ES VS E0
α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ β
Definition
mat_ID Material identifier.
(Integer, maximum 10 digits)
Unit Identifier Unit Identifier.
eos_title EOS title.
C1 C1 coefficient .
(Real)
[ Pa ]
C2 C2 coefficient.
(Real)
[ Pa ]
a A coefficient.
(Real)
b b coefficient.
(Real)
ER Internal energy per unit reference volume.
(Real)
[ J m 3 ]
ES Sublimation energy per unit reference volume.
(Real)
[ J m 3 ]
VS Sublimation relative volume.
(Real)
[ m 3 ]
E0 Initial energy per unit reference volume.
(Real)
[ J m 3 ]
α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ coefficient.
(Real)
β β coefficient.
(Real)
Example (Aluminum)
#RADIOSS STARTER
/UNIT/1
unit for mat
                   g                  cm                 mus
#-  2. MATERIALS:
/MAT/HYD_JCOOK/1/1
Aluminum
#              RHO_I               RHO_0
                 2.8                   0
#                 E                   nu
                .734                 .33
#                  A                   B                   n              epsmax              sigmax
               .0024               .0042                  .8                   0               .0068
#               Pmin
              -.0223
#                  C           EPS_DOT_0                   M               Tmelt               Tmax
                .062                1E-6                   1                1220                   0
#              RHOCP                                                         T_r
             2.59E-5                                                           0
/EOS/TILLOTSON/1/1
Aluminum
#                 C1                  C2                   A                   B
                .752                 .65                  .5                1.63
#                 ER                  ES                  VS                  E0
                .135                .081                 1.1                   0
#              ALPHA                BETA
                   5                   5
/FAIL/JOHNSON/3
#                 D1                  D2                  D3                  D4                  D5
                .112                .123                -1.5                .007                   0
#              EPS_0  Ifail_sh  Ifail_so                                    Dadv               Ixfem
                1E-6         0         1                                       0                   0
#ENDDATA
/END
Input Example
"Metallic Equation of State for Hypervelocity Impact" J.H. Tillotson, General Dynamics, 1962:
Material ρ 0 [ g c m 3 ] g/cm3 C1 [ Mbar ] C2 [ Mbar ] a b ER [ Mbar ] α MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySdegaaa@3792@ β ES [ Mbar ] VS
Cu 8.9 1.390 1.10 0.5 1.50 2.892 5 5 0.123 1.18
Fe 7.8 1.279 1.05 0.5 1.50 0.741 5 5 0.190 1.21
Al 2.7 0.752 0.65 0.5 1.63 0.135 5 5 0.081 1.10
  1. With μ = ρ ρ 0 − 1
    V = 1 ρ the specific volume
    η = 1 + μ
    x = 1 − ρ 0 ρ
    and E being the internal energy per unit reference volume.
    The pressure is defined by:
    Region 1: μ ≥ 0 (1)
    P = C 1 μ + C 2 μ 2 + ( a + b ω ) η E
    with ω=1+ E E R   η 2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaaeaaaaaaaaa8 qacqaHjpWDcqGH9aqpcaaIXaGaey4kaSYaaSaaa8aabaWdbiaadwea a8aabaWdbiaadweapaWaaSbaaSqaa8qacaWGsbaapaqabaGccaaMi8 +dbiabeE7aO9aadaahaaWcbeqaa8qacaaIYaaaaaaaaaa@41F5@
    Region 2: μ < 0 V V 0 < V S and E < E S (2)
    P = C 1 μ + ( a + b ω ) η E
    Region 3: μ < 0 , V V 0 > V S or V V 0 < V S and E ≥ E S (3)
    P = C 1 e β x e − α x 2 μ + ( a + b e − α x 2 ω ) η E
  2. Equations of state are used by Radioss to compute the hydrodynamic pressure and are compatible with the material laws:
    • /MAT/LAW3 (HYDPLA)
    • /MAT/LAW4 (HYD_JCOOK)
    • /MAT/LAW6 (HYDRO or HYD_VISC)
    • /MAT/LAW10 (DPRAG1)
    • /MAT/LAW12 (3D_COMP)
    • /MAT/LAW49 (STEINB)
    • /MAT/LAW102 (DPRAG2)
    • /MAT/LAW103 (HENSEL-SPITTEL)
