/GRNOD
Block Format Keyword Node Groups
Input Type Keywords: Node Group
- Keyword
 - Input Type
 - /GRNOD/BOX
 - Box
 - /GRNOD/GEN_INCR
 - Generate list by increment
 - /GRNOD/GENE
 - List of nodes with generation
 - /GRNOD/GRBEAM
 - Beam group
 - /GRNOD/GRBRIC
 - Brick group
 - /GRNOD/GRNOD
 - Node groups
 - /GRNOD/GRQUAD
 - Quad group
 - /GRNOD/GRSHEL
 - 4 node shell group
 - /GRNOD/GRSH3N
 - 3 node shell group
 - /GRNOD/GRSPRI
 - Spring group
 - /GRNOD/GRTRUS
 - Truss group
 - /GRNOD/LINE
 - List line groups
 - /GRNOD/MAT
 - Material
 - /GRNOD/NODE
 - List of nodes
 - /GRNOD/NODENS
 - Unsorted node numbers
 - /GRNOD/PART
 - Part
 - /GRNOD/PROP
 - Property
 - /GRNOD/SUBMODEL
 - Submodel
 - /GRNOD/SUBSET
 - Subset
 - /GRNOD/SURF
 - Surface
- A node group is a set of nodes. It can
                be defined explicitly by a list of:
- nodes
 - entering a first and last node ID range which defines the group
 - submodels (all nodes belonging to the listed submodel are included)
 - submodels (all nodes defined by /NODE or /CNODE in the listed submodel are included)
 - subsets or parts (all nodes belonging to the listed subset/part are included)
 - property sets or materials (all nodes belonging to an element having those Property Type's/MID's are included)
 - groups of nodes
 - element groups (all nodes connected to those elements are included)
 - a box (all nodes within a defined box are included)
 - an unsorted node list: same as list of nodes, but the nodes are stored in the order of input not sorted numerically as with other options (only needed in /INTER/TYPE8 and /XELEM option).
 - Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
