Lines
Block Format Keyword
Input Type Keywords
- Keyword
 - Input Type
 - /LINE/SEG
 - Segments
 - /LINE/SUBSET
 - Subset
 - /LINE/SUBMODEL
 - Submodel
 - /LINE/PART
 - Part
 - /LINE/MAT
 - Material
 - /LINE/PROP
 - Property
 - /LINE/GRTRUS
 - Groups of trusses
 - /LINE/GRBEAM
 - Group of beam
 - /LINE/GRSPRI
 - Group of springs
 - /LINE/LINE
 - Lines
 - /LINE/SURF
 - Surface
 - /LINE/EDGE
 - Edges of the Surfaces
 - /LINE/BOX or /LINE/BOX2
 - Box
- A line is a set of 2-node
                segments and can be defined:
- explicitly, with segment connectivity
 - by box
 - by subsets, parts, properties or materials (all trusses and beams belonging to these entities are used to define the line)
 - by submodels (all trusses, beams and springs belonging to parts defined in the specified submodels are used to define the line)
 - by truss, beam or spring groups
 - by a surface (all lines of the surface are used)
 - by edges (edges of the surfaces are used)
 - with other lines
