/IMPL/DT/1
Engine Keyword Implicit time step control method 1.
/IMPL/DT/1
lt_w L_dtn
Definition
| lt_w | If the solution of a time
                                step converges within It_w iterations, the next
                                time step will be increased by a factor of
Scale factor for
                                increasing the time step.
| L_dtn | Maximum number of
                                iterations before resetting and decreasing the time step by a factor
                                of
Scale factor for
                                decreasing the time step.
- If /IMPL/DT/1, /IMPL/DT/2, or /IMPL/DT/3 are not present, the only time step controls are /IMPL/NCYCLE/STOP and /IMPL/DT/STOP. In the case of divergence, the time step will be reduced by half and repeated.
