| ELE_ID |
                                3 nodes or 4 nodes shell element
                                        identifier. (Integer, maximum 10 digits)
                                | npg |
                                Number of in-plane integration
                                    points. |
                                | nb_integr |
                                Number of integration point through
                                    the thickness. |
                                | LARGE |
                                Line format flag:
                                            - = 1
                                            - Large format
                                            - (16 character per field)
                                | EPSxx |
                                Strain tensor component xx in the
                                    global coordinate system. |
                                | EPSyy |
                                Strain tensor component yy in the
                                | EPSzz |
                                Strain tensor component zz in the
                                | EPSxy |
                                Strain tensor component xy in the
                                | EPSyz |
                                Strain tensor component yz in the
                                | EPSzx |
                                Strain tensor component zx in the
                                | T |
                                Parametric position of the
                                    integration points throughout the thickness (between -1 and 1
                                    inclusive). |
