/INITRUSS/FULL
Block Format Keyword Describes the initial state for truss elements. All values defined in this card will be applied at the beginning on the computation.
/INITRUSS/FULL/unit_ID | |||||||||
truss_ID | prop_type | ||||||||
EINT | F | AREA | εp |
Definition
unit_ID | Optional unit
spring_ID | Element
identifier (Integer) |
prop_type | Property set
(Integer) |
EINT | Total internal energy
(Real) |
[J] |
F | Truss element normal
force (Real) |
[N] |
AREA | Cross-sectional area
of the truss (Real) |
[m2] |
εp | Plastic
strain (Real) |
