/INIVEL/AXIS
Block Format Keyword Initialize both translational and rotational velocities on a group of nodes in a given coordinate system.
/INIVEL/AXIS/inivel_ID/unit_ID
inivel_axis_title
Dir frame_ID grnd_ID
Vxt Vyt Vzt Vr
Definition
inivel_ID Initial velocity block identifier.
(Integer, maximum 10 digits)
unit_ID Unit Identifier.
inivel_axis_title Initial velocity block title.
Dir Direction X, Y, and Z of the frame defining the rotation axis.
(Text)
frame_ID Frame identifier. frame_ID is obligatory input.
If not given, the initial velocities are applied with respect to the global coordinate system.
(Integer)
grnd_ID Node group on which specified initial velocities are applied.
(Integer)
Vxt X component in the local frame of the translational velocity.
(Real)
[ m s ] MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaamWaaeaada Wcaaqaaiaab2gaaeaacaqGZbaaaaGaay5waiaaw2faaaaa@39DE@
Vyt Y component in the local frame of the translational velocity.
(Real)
Vzt Z component in the local frame of the translational velocity.
(Real)
Vr Rotational velocity about the rotational axis.
(Real)
[ rad s ]
  1. The keyword defines initial rigid body type of motion (translational and rotational) of a group of nodes (for example, initial velocity for rollover simulation of a vehicle).
  2. The initial nodal velocity is calculated as:(1)
    v ( M ) = V t + V r U ‖ U ‖ ∧ O M
    Where,
    U
    Vector defining the rotation axis.
    O
    Center of the local coordinate system
    M
    Nodal point
    V r
    Rotation velocity
    V t
    Vector of translational velocity
  3. This option cannot be used when /INIVEL/TRA or /INIVEL/ROT is applied on the same node.
