/RWALL/THERM
Block Format Keyword Describes the ALE rigid wall.
/RWALL/THERM/wall_ID
wall_title
  Slide grnd_ID1 grnd_ID2
Dsearch fric ϕ
XM YM ZM
XM1 YM1 ZM1
fct_IDT   FscaleT R
Definition
wall_ID Rigid wall identifier.
(Integer, maximum 10 digits)
wall_title Rigid wall title.
Slide Sliding flag.
= 0
Sliding
= 1
Tied
= 2
Sliding with friction
(Integer)
grnd_ID1 Node group defining secondary nodes to be added to the rigid wall.
(Integer)
grnd_ID2 Node group defining secondary nodes to be deleted from the rigid wall.
(Integer)
Dsearch Distance for secondary node search.
(Real)
[ m ]
fric Friction.
(Real)
ϕ Diameter.
(Real)
[ m ]
XM X coordinate of M.
(Real)
[ m ]
YM Y coordinate of M.
(Real)
[ m ]
ZM Z coordinate of M.
(Real)
[ m ]
XM1 X coordinate of M1.
(Real)
[ m ]
YM1 Y coordinate of M1.
(Real)
[ m ]
ZM1 Z coordinate of M1.
(Real)
[ m ]
fct_IDT Wall temperature function.
(Integer)
FscaleT Wall temperature scale factor.
(Real)
[ K ]
R Thermal resistance R = d / K.
d
Length
K
Thermal conductivity
(Real)
[ m ⋅ K W ]
  1. Only the plane type of rigid wall is available for /RWALL/THERM. Coordinate of M and M1 are used to define the normal of the plane.
  2. The first input format used to define the rigid wall is the coordinates of point M, at the location of the rigid wall.
  3. The second input is the coordinates of point M1, defining the outward normal direction of the wall.
  4. The secondary nodes can be defined as a list of nodes and/or as the nodes initially at a distance less than Dsearch from the wall.
