/SENSOR/ACCE
Block Format Keyword Describes the sensors used to activate or deactivate an object according to accelerometer.
| /SENSOR/ACCE/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| Nacc | |||||||||
| accel_ID | Dir | Γmin | Tmin | ||||||
Definition
| sens_ID | Sensor
identifier. (Integer, maximum 10 digits) |
| unit_ID | Optional unit
| sens_title | Sensor
title. (Character, maximum 100 characters) |
| Tdelay | Time
delay. (Real) |
| Nacc | Number of
accelerometers (Nacc ≤
6). (Integer) |
| accel_ID | Accelerometer
identifier. (Integer) |
| Dir | Direction. 4 (Text) |
| Γmin | Minimum absolute value
of acceleration. (Real) |
| Tmin | Minimum time duration
before activation when criteria is reached. 3 (Real) |
- Sensors can be used to activate airbags, imposed forces, pressures, and fixed velocities.
- Sensors can be used to activate or deactivate these elements: brick, quad, shell, truss, beam, spring or 3N Shell with /ACTIV.
- Sensor is activated (at Tsensor) if one of the accelerometers gives an
acceleration greater than Γmin during a time greater than Tmin:
Tsensor = Tdelay + Tmin
with, Tmin (time when the criteria is reached).
- Dir defines
the acceleration direction:
- X
- X direction
- Y
- Y direction
- Z
- Z direction
- XY
- XY plane
- YZ
- YZ plane
- ZX
- ZX plane
- XYZ
- total acceleration
