/SENSOR/TEMP
Block Format Keyword Describes a sensor activated when the temperature in a group of nodes reaches one of the prescribed limit values during a minimum time duration.
| /SENSOR/TEMP/sens_ID/unit_ID | |||||||||
| sens_title | |||||||||
| Tdelay | |||||||||
| Grnod_ID | Tempmax | Tempmin | Tempmean | Tmin | |||||
Definition
| sens_ID | Sensor identifier. (Integer, maximum 10 digits)  |
| unit_ID | (Optional) Unit Identifier. (Integer, maximum 10 digits)  |
| sens_title | Sensor title. (Character, maximum 100 characters)  |
| Tdelay | Time delay. Default = 0.0 (Real)  |
| Grnod_ID | Node group
                                        identifier. (Integer)  |
| Tempmax | Maximum temperature
                                        limit. Default = 1E+20 (Real)  |
| Tempmin | Minimum temperature
                                        limit. Default = 0 (Real)  |
| Tempmean | Average temperature
| Tmin | Minimum time duration before
                                    activation when criteria is reached.  Default = 0 (Real)  |
- Sensors can be used to terminate a simulation at specific conditions with the Engine keyword /STOP/LSENSOR.
 - The sensor is activated when one the following conditions is
                        reached:
- Maximum of nodal temperature > Tempmax during time > Tmin + Tdelay
 - Minimum of nodal temperature < Tempmin during time > Tmin + Tdelay
 - Average temperature of node group > Tempmean during time > Tmin + Tdelay
