*SET_SEGMENT
LS-DYNA Input Interface KeywordDefines a surface defined by 3 or 4 node segments.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SET_SEGMENT_{OPTION1}_{OPTION2} | |||||||
| set_ID | |||||||
| N_ID1 | N_ID2 | N_ID3 | N_ID4 |
| TYPE | E1 | E2 | E3 | E4 | E5 | E6 | E7 |
Definition
| OPTION1 |
| OPTION2 |
| set_ID | Node set identifier. (Integer) |
| N_ID1 - N_ID4 | Node IDs, 4 per line. (Integer) |
| TYPE |
No default |
| E1 - E7 | Entity IDs, 7 per line (Integer) |
- This keyword maps to /SET.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
