Offset an implicit body. The offset can be made into a hollow shell.
On the Implicit Modeling ribbon, select the
Offset tool.
- Optional:
For Visualization Quality, select from
Low to Very High quality,
which corresponds to a low to very high density of elements. A higher quality
produces sharper geometry features but is more computationally intensive. When
creating a complicated function, it’s recommended to work using a lower quality
and then switch to a higher quality after the function is complete.
Select a body.
- Optional:
To create a hollow shell, turn on Shell. This will
hollow the model and populate the region between the original and offset
surfaces with material.
- Optional:
Select the shell's offset direction. The surface offset always propagates in a
direction normal to the original surface.
- Inward (negative): Offset the shell inward.
- Outward (positive): Offset the shell
outward.
- Both: Offset the shell both inward and
outward.
- Symmetry: Symmetrically offset the shell both
inward and outward.
- Optional:
Define the shell thickness.
Define the offset amount, which can be a constant value, a variable, or a
field.
Note: Not all fields in Implicit Modeling are true signed
distance fields, where each scalar value in space denotes the precise
distance to the surface. When a field is not a signed distance field, offset
operations might not produce constant or precise offset thicknesses. For
example, care should be taken when offsetting a surface lattice, such as a
Gyroid as these are close to, but not exactly, signed distance
fields.
- Inward Distance: Define the distance to offset
the body inward.
- Outward Distance: Define the distance to offset
the body outward.
Click OK.
Right-click and mouse through the check mark to exit, or double-right-click.
