Adding Calculated Columns
    NOTE  |
    · User defined columns can only be added when there is an available data source. · The user-defined columns are added in the topmost data source in the Data Sources list or in the joined or combined data source. · An auto key can only be created once. · Ranking requires a numeric source column. · Time bucketing requires a time source column and each source column can only be used once. · Numeric bucketing requires a numeric source column. · Text grouping requires a text source column. ·           The added
			 user-defined column displays on the Data Preview with
			 a pen symbol   |
