Select Variables
Variables are the columns of data used by visualizations. For example, if you have a database of sales information broken down by product, you might associate the total amount of sales for a given with the Size variable in a Treemap. You could also associate the difference between this year’s sales and last year’s sales to the Color variable for the same Treemap. This simple configuration will let you see at a glance which products are bringing in the most revenue and which products are increasing and decreasing in sales.
Each visualization uses a different set of variables, depending on the capabilities of the visualization:
Snapshot Visualizations
    Visualization  |
    Variables  |
    Bar Graph – Vertical  |
    Bar Graph - Horizontal  |
    Box Plot  |
    Bullet Graph - Vertical  |
    Bullet Graph - Horizontal  |
    Categorical Line Graph  |
    Circle Pack  |
    Donut Chart  |
    Donut Gauge  |
    Dot Plot – Vertical  |
    Dot Plot – Horizontal  |
    Funnel Chart  |
    Heat Matrix  |
    Map Plot  |
    Network Graph  |
    Numeric Line Graph  |
    Numeric Line Graph – Vertical  |
    Numeric Needle Graph  |
    Numeric Needle Graph – Horizontal  |
    Numeric Stacked Needles  |
    Numeric Stacked Needles – Horizontal  |
    Pareto Chart  |
    Pie Chart  |
    Record  |
    Scatter Plot  |
    X, Y, Size, Color, Opacity, Shape, Ref Lines, Details, Style  |
    Scatter Plot 3D  |
    Shapes  |
    Surface Plot  |
    Surface Plot 3D  |
    Table  |
    Ticker Tile  |
    Treemap  |
    Waterfall Chart  |
