Connector for XML
The XML connector allows the retrieval and processing of XML files, either from a disk, a Text, or from a defined URL.
1. Select the XML File Source.
2. Enter the Record XPath which allows the selection of records within the XML document (e.g., //myroot/items/item). This property can be parameterized.
3. Select either the dot (.) or comma (,) as the Decimal Separator.
4.     Click
 to the fetch the schema based on the connection
	 details. Consequently, the list of columns with the data type found
	 from inspecting the first ‘n’ rows of the input data source is populated
	 and the Save button is enabled.
5. You can also opt to load or save a copy of the column definition.
6.     Click
	 to add columns and specify their properties:
    Property  |
    Description  |
    Name  |
    The column name of the source schema.  |
    XPath  |
    The XPath of the source schema.  |
    Type  |
    The data type of the column. Can be a Text, Numeric, or Time  |
    Date Format  |
    The format when the data type is Time.  |
    Enabled  |
    Determines whether the message should be processed.  |
To delete a column,
	 check its
 or
	 all the column entries, check the topmost
, then click .
6. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
