Connector for Google Cloud
Google Cloud connector allows for retrieval of the file from Google Cloud storage. This connector allows JSON/XML/Text/Excel files to be read from the Google Cloud storage.
1. Enter the following information:
    Property  |
    Description  |
    Bucket  |
    Google Cloud bucket where the file resides.  |
    Access Key  |
    Access key to your Google Cloud service account.  |
    Secret Key  |
    Secret key to your Google Cloud service account. To
			 test the connection, click  If   |
    File Path  |
    Cloud storage resource path.  |
2. Select the Data Type.
3. Click to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
4. You can also opt to load or save a copy of the column definition.
5. Click to add columns to the Google Cloud connection that represent sections of the message. Then enter or select:
    Property  |
    Description  |
    Name  |
    The column name of the source schema.  |
    JsonPath/Column Index/XPath  |
    The JsonPath/Column Index/XPath of the source schema.  |
    Type  |
    The data type of the column. Can be a Text, Numeric, or Time  |
    Date Format  |
    The format when the data type is Time.  |
    Enabled  |
    Determines whether the message field should be processed.  |
    NOTE  |
    To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them. For example: yyyy-MM-dd HH:mm:ss.SSSSSS  |
To delete a column,
	 check its
 or
	 all the column entries, check the topmost
, then click .
 displays, ensure
			 the
