Use Fast Results Switching to compare results from different design
        studies.
                Display an analysis result in the modeling window.
                    Note: You can do this from either a saved bookmark or the
 (Results plot) icon on the Analysis workbench
                        toolbar.
                In the Project tree, choose another analysis to display.
The modeling window will instantly update to
                    display the new geometry and analysis results.
                Switch between analyses as quickly as you desire.
