The Twin Activate debugger is an interface that lets you control the advancement of a simulation so that, at every pause, you can inspect
and modify block objects, which includes model signals.
The process of simulating a model occurs in three phases: Evaluation, Compilation and Simulation. The Evaluation and Compilation
phases occur first and generate a structure that is processed during the Simulation phase.
Use the MAT Explorer interface to explore and load variables from one or more .MAT files, providing a visual way to see the contents of selected .MAT files and to import variables into an OML session.
Learn how to set up, run, and troubleshoot simulations.
Set Simulation Parameters
Before executing a simulation, you can define parameters for simulation time, zero-crossing and solvers.
Create a Results File
Capture and review simulation results including the signals of all blocks in a model.
Run a Simulation
Execute a simulation with the Run tool on the ribbon.
View Results
Discover options to review, display, and export results.
Troubleshoot
Learn troubleshooting techniques for common simulation issues.
Debugger
The Twin Activate debugger is an interface that lets you control the advancement of a simulation so that, at every pause, you can inspect and modify block objects, which includes model signals.
Functional Mock-Up Interface Support
The Functional Mock-Up Interface (FMI) is an emerging standard for creating interfaces between different tools.
Simulation Phases
The process of simulating a model occurs in three phases: Evaluation, Compilation and Simulation. The Evaluation and Compilation phases occur first and generate a structure that is processed during the Simulation phase.
