Magnet (vector): linear approximation
Presentation
These models ( Linear magnet described by the Cartesian / cylindrical / spherical vector Br ) define a B(H) dependence of linear demagnetization in Flux (not available in material manager).
Main characteristics:
- the mathematical model and the direction of magnetization are associated
 - same number of materials and/or coordinate systems than regions
Mathematical model
In the direction of magnetization the model is a straight line.
The corresponding mathematical formula is written as follows:
Β(Η)=μ0μrΗ+ Br
where:
- μ0 is the permeability of vacuum, μ0 = 4 π 10-7 H/m
 - μr is the relative permeability (recoil line slope)
 - Br is the remanent flux density T
The shape of the B(H) dependence is given in the opposite figure:
Direction of magnetization
The direction of magnetization is “associated” with the model. Three models are provided: Cartesian, cylindrical or spherical vector.
Cartesian magnetization
The mathematical model is the linear model previously described.
The B(H) dependence is defined by the following relationship
            in a Cartesian coordinate system:
where:
 is the remanent flux density defined by three components following the three axes
               of the Cartesian coordinate system: ( Brx, Bry,
               Brz) - μr is the tensor of relative permeability; the three numerical values ( μrx, μry, μrz) correspond to the three axes of the Cartesian coordinate system
Cylindrical magnetization
The B(H) dependence is defined by the following relationship in a cylindrical coordinate
            system:
where:
 is the remanent
               flux density defined by three components following the three axes of the cylindrical
               coordinate system: ( Brr, Brθ and Brz) - μ r is the relative permeability
| radial (Brr ) | orthoradial (Brθ) | axial (Brz) |
Spherical magnetization
The B(H) dependence is defined by the following relationship in a spherical coordinate
            system:
where:
               density defined by three components following the three axes of the spherical
               coordinate system: ( Brr, Brθ et Brφ) - μ r is the relative permeability
radial (Brr ):
