Show recommended configuration
A project analysis can be done to provide some recommendations in terms of number of cores and solver configuration.
When you click on Show recommended configuration in the dialog box of a Solving scenario, in the Output part of Flux, you have information on the dimension, the application and the number of nodes of your Flux project. You have also the current settings and the recommendations for the number of cores (defined in the Supervisor), the linear solver (selected in the Solving options) and if the Parametric distribution is enabled or not in the scenario selected.
- Change the number of cores, see How to parallelize the solving on a single machine
 - Change the solver, see Solving a linear system: Flux solvers
 - Enable or not the Parametric Distribution, see How to set up a parametric distribution on a single machine
