RADIATION_SURFACE
Specifies radiative boundary conditions for the enclosure, p1_model and discrete_ordinate radiation models.
For the enclosure model, a radiation heat flux condition is applied to the surface. For the p1_model the condition specifies the emissivity of the surface used by the Marshak boundary condition. For the discrete_ordinate model, the condition specifies surface properties, such as emissivity and diffuse fraction. The emissivity is used to account for radiation emission from the surface. For example, , where is the emissivity, is Stefan-Boltzmann constant, and is the wall temperature.
AcuSolve Command
RADIATION_SURFACE("name") {parameters...}
Qualifier
User-given name.
- shape (enumerated) [no default]
- Shape of the surfaces in this set.
- three_node_triangle or tri3
- Three-node triangle.
- four_node_quad or quad4
- Four-node quadrilateral
- six_node_triangle or tri6
- Six-node triangle.
- element_set or elem_set (string) [no default]
- User-given name of the parent element set.
- surfaces (array) [no default]
- List of element surfaces.
- surface_sets (list) [={}]
- List of surface set names (strings) to use in this command. When using this option, the connectivity, shape, and parent element of the surfaces are provided by the surface set container and it is unnecessary to specify the shape, element_set and surfaces parameters directly to the RADIATION_SURFACE command. This option is used in place of directly specifying these parameters. In the event that both of the surface_sets and surfaces parameters are provided, the full collection of surface elements is read and a warning message is issued. The surface_sets option is the preferred method to specify the surface elements. This option provides support for mixed element topologies and simplifies pre-processing and post-processing.
- type (enumerated) [=wall]
- Type of the boundary surface. For the enclosure and
p1_model radiation models, the type can be either
wall or opening. For the
discrete_ordinate radiation model the type can be
wall, opening or
radiation_interface.
- auto
- Automatic radiation surface treatment to determine whether a surface is treated as type = wall or type = opening. Used with all radiation models.
- wall
- Wall. Requires an emissivity_model for all radiation models and agglomeration for enclosure.
- opening
- Opening. Requires emissivity_model and opening_temperature.
- radiation_interface
- Radiation_interface. Enables the transmission and reflection of radiative intensity at an interface between two participating media. Available when radiation = discrete_ordinates.
- radiation_interface_type (enumerated) [=internal]
- The type of radiation_interface is specified through radiation_interface_type. The parameter has two values: internal and external. If radiation_interface_type = internal, there must be a participating media on each side of an interface, that is, the material for each adjacent ELEMENT_SET has a radiation_model. For this condition, the transfer of radiative intensity is both transmitted and reflected at the interface. If radiation_interface_type = external, there is a participating media on one side of an interface. The radiative intensity in the medium surrounding the model is calculated using the mathematical model. The external radiation interface is used with external_emissivity_model and external_temperature. The radiation_interface_type requires radiation_interface.
- external_emissivity_model (string) [=none]
- User-given name of the external emissivity model of an exterior facing surface if radiation_interface_type = external.
- external_temperature (real)>=0 [= 273.15]
- Defines the temperature of the fluid surrounding the domain if radiation_interface_type = external.
- external_temperature_multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the external temperature. If none, no scaling is performed.
- specular_ordinate_averaging (enumerated) [=one_ordinate]
- The specular ordinate averaging parameter is used to determine the direction of the specular ordinate. Two averging methods are available: one_ordinate and three_ordinates. If specular_ordinate_averaging = one_ordinate, this method is to search for the closest specular ordinate direction, if specular_ordinate_averaging = three_ordinates, the specular ordinate direction is calculated by averaging the three closest ordinate directions. This parameter is used for specular interfaces when the diffusion fraction is less than 1.0. Requires radiation_interface. Available when radiation = discrete_ordinates.
- emissivity_model (string) [no default]
- User-given name of the emissivity model. Used with wall and opening types.
- opening_temperature or temp (real) >=0 [=273.15]
- Opening temperature. Used with opening type.
- opening_temperature_multiplier_function (string) [=none]
- User-given name of the multiplier function for scaling the opening temperature. If none, no scaling is performed. Used with opening type.
- agglomeration (boolean) [=on]
- Flag specifying whether to agglomerate the surface elements. Used with wall type. A value of on requires max_agglomeration_surfaces, max_agglomeration_angle and max_agglomeration_radius.
- max_agglomeration_surfaces (integer) >=0 [=25]
- Maximum number of surfaces in one agglomeration. Used with on agglomeration. If zero, this option is ignored.
- max_agglomeration_angle or angle (real) >=0 <=180 [=10]
- Maximum angle between surfaces allowed in any agglomeration. Used with on agglomeration.
- max_agglomeration_radius or radius (real) >=0 [=0.25]
- Maximum radius of agglomeration. Used with on agglomeration. If zero, this option is ignored.
- integrated_output_frequency or intg_freq (integer) >=0 [=1]
- Time step frequency at which to output the integrated radiation heat flux. If zero, this option is ignored.
- integrated_output_time_interval or intg_intv (real) >=0 [=0]
- Time frequency at which to output the integrated radiation heat flux. If zero, this option is ignored.
- nodal_output_frequency or nodal_freq (integer) >=0 [=0]
- Time step frequency at which to output radiation heat flux at the nodes of the surface. If zero, this option is ignored.
- nodal_output_time_interval or nodal_intv (real) >=0 [=0]
- Time frequency at which to output radiation heat flux at the nodes of the surface. If zero, this option is ignored.
- diffused_fraction (real) [=1.0]
- Diffused fraction defines the proportion of reflected radiation intensity at a surface that is diffused.
This command specifies a radiation heat flux condition on a set of surfaces (element faces). This condition is coupled to all other radiation surfaces. The RADIATION command provides a detailed description of this coupling.
ELEMENT_SET( "interior" ) {
shape = four_node_tet
elements = { 1, 8, 3, 4, 9 ;
3, 3, 4, 9, 5 ;
RADIATION_SURFACE( "wall" ) {
type = wall
shape = three_node_triangle
element_set = "interior"
surfaces = { 1, 12, 9, 3, 4 ;
3, 52, 5, 3, 4 ; }
emissivity_model = "emissivity"
integrated_output_frequency = 2
}specifies a radiation heat flux condition to be applied to two surfaces of the element set "interior" using the emissivity model "emissivity", and the integral of the radiation heat flux is to be output every two steps.
- Element Shape
- Surface Shape
- four_node_tet
- five_node_pyramid
- five_node_pyramid
- four_node_quad
- six_node_wedge
- six_node_wedge
- four_node_quad
- eight_node_brick
- four_node_quad
- ten_node_tet
- six_node_triangle
The surfaces parameter contains the faces of the element set. This parameter is a multi-column array. The number of columns depends on the shape of the surface. For three_node_triangle, this parameter has five columns, corresponding to the element number, of the parent element set, a unique, within this set surface number, and the three nodes of the element face. For four_node_quad, surfaces has six columns, corresponding to the element number, a surface number, and the four nodes of the element face. For six_node_triangle, surfaces has eight columns, corresponding to the element number, a surface number, and the six nodes of the element face. One row per surface must be given. The three, four, or six nodes of the surface may be in any arbitrary order, since they are reordered internally based on the parent element definition.
1 12 9 3 4
3 52 5 3 4RADIATION_SURFACE ( "no-slip wall" ) {
surfaces = Read( "wall.srf" )
}SURFACE_SET( "tri faces" ) {
surfaces = { 1, 1, 1, 2, 4 ;
2, 2, 3, 4, 6 ;
3, 3, 5, 6, 8 ; }
volume_set = "tetrahedra"
SURFACE_SET( "quad faces" ) {
surfaces = { 1, 1, 1, 2, 4, 9 ;
2, 2, 3, 4, 6, 12 ;
3, 3, 5, 6, 8, 15 ; }
shape = four_node_quad
volume_set = "prisms"RADIATION_SURFACE ( "no-slip wall" ) {
surface_sets = {"tri_faces", "quad_faces"}
}tri faces
quad facesRADIATION_SURFACE ( "no-slip wall" ) {
surface_sets = Read("surface_sets.srfst")
}The mixed topology version of the RADIATION_SURFACE command is preferred. This version provides support for multiple element topologies within a single instance of the command and simplifies pre-processing and post-processing. In the event that both the surface_sets and surfaces parameters are provided in the same instance of the command, the full collection of surface elements is read and a warning message is issued. Although the single and mixed topology formats of the commands can be combined, it is strongly recommended that they are not.
type = wall
agglomeration = on
max_agglomeration_surfaces = 100
max_agglomeration_angle = 20
max_agglomeration_radius = 0.5
diffused_fraction = 0.9
}specifies that each agglomeration contains no more than 100 surfaces, the angles between the outward normals of these surfaces are no more than 20 degrees, and the radius of the agglomerated surface no greater than 50 percent of the radius of the entire surface set. In addition to these constraints, each agglomeration must contain only one emissivity model. Several parameters must be the same across all radiation surfaces; these are given in the RADIATION command. When accuracy is more important than the cost of computing the view factors, for example, a small, hot surface, agglomeration should be set to off. In this case the radiation heat flux will be computed for each element face in the set.
The opening type provides a method of fully enclosing a fluid domain that is not be completely surrounded by walls. This type is appropriate for inlets, outlets, and surfaces that approximate infinity in external flows. The primary assumption is that the surface is at a single given temperature of opening_temperature. This assumption allows the entire set to be combined into one agglomerated facet, so agglomeration and associated parameters are ignored. An opening is typically modeled as a black body, with an emissivity of one. However, other emissivity models may be used with an opening.
RADIATION_SURFACE( "inlet" ) {
type = opening
emissivity_model = "black body"
opening_temperature = 1
opening_temperature_multiplier_function = "inlet temperature"
MULTIPLIER_FUNCTION( "inlet temperature" ) {
type = cubic_spline
curve_fit_values = { 0, 295 ;
12, 312 ;
24, 320 ; }
curve_fit_variable = time
EMISSIVITY_MODEL( "black body" ) {
type = constant
emissivity = 1
}If either integrated_output_frequency or integrated_output_time_interval is non-zero, the surface integral of the radiation heat flux will be output at the end of the run. If both are zero, no integrated radiation heat flux data is written to disk.
Similarly, if either nodal_output_frequency or nodal_output_time_interval is non-zero, the nodal values of the radiation heat flux will be output at the end of the run. If both are zero, no nodal radiation heat flux data is written to disk.
Run times may not coincide with integrated_output_time_interval or nodal_output_time_interval. In these cases, the corresponding data are output for every time step which passes through a multiple of output_time_interval or nodal_output_time_interval.
Once the surface quantities have been written to disk, they can be translated to other formats using the AcuTrans program and other post-processing modules; see the AcuSolve Programs Reference Manual for details.
For the discete_ordinate radiation model, exchange of radiative intensity occurs at the interface between participating media. For this case the RADIATION_SURFACE type is set to radiation_interface and the radiation_interface_type can be either internal or external. For the internal radiation_interface_type, the condition is applied between two participating media (two media both with a MATERIAL_RADIATION_MODEL). For the external radiation_interface_type, the RADIATION_SURFACE is applied to the boundary of a semi-transparent media (has a MATERIAL_RADIATION_MODEL) and models radiative exchange with the surrounding environment. The exchange of radiative intensity depends on the diffused_fraction of the interface and the refractive indices of the media. The different scenarios are described below.
Reflection and Transmission for Specular Interfaces of Type Internal
Figure 1. . Reflected and refracted directions at the interface between two participating media of different refractive indices (n1 < n2). For the medium of higher refractive index if the incoming direction is greater than the critical angle total internal reflection occurs (no transmission occurs across the interface). This is represented by the gray dashed lines in the image.
where is the unit reflected ordinate direction vector and also represents the current ordinate direction being solved. The equivalent calculation can also be performed for medium two.
providing the expression under the radicand is greater than zero; otherwise total internal reflection occurs, which is discussed later.
The actual reflected and refracted directions differ slightly from the calculated direction since these directions will unlikely coincide with a discrete ordinate direction. Since the number of directions is governed by the order of radiation_quadrature in EQUATION (S2-S16), higher quadrature orders are more accurate for interface problems.
The extremity being an intensity ray that grazes the interface and is transmitted exactly at the critical angle into the other domain.
and the transmitted proportion from , or transmittance, is given by .
In the second medium, for the current scenario where , if the radiative intensity is, as for medium one, partially reflected and partially transmitted. The reflection coefficient is as described above since . If , then total internal reflection occurs and and , meaning no transmission of radiative intensity into the second medium or from the first medium. This is shown in the image above with the gray dashed lines.
For , the subscripts of the above analysis must be exchanged, and total internal reflection will now occur in medium one.
Reflection and Transmission for Diffuse Interfaces of Type Internal
For diffuse interfaces the diffused_fraction = 1.
Where is the ratio of refractive indices. always represents the medium with higher refractive index and the medium of lower refractive index.
The transmission from medium one to two is given by .
For the reverse direction the reflectance and transmittance are given by and , respectively.
Reflection and Transmission for Partially Specular and Partially Diffuse Interfaces of Type Internal
For partially specular and partially diffuse interfaces 0.0 < diffused_fraction < 1.0.
where is the diffuse fraction, is the outgoing specular component of radiative intensity, and is the outgoing diffuse component of radiative intensity. For example, in medium one in the image above the components would be and .
Reflection and Transmission for Diffuse Interfaces of Type External
where is the exterior emissivity and is set to one in AcuSolve, is the Stefan-Boltzmann constant, and is the temperature of the surrounding fluid. At the external interface is transferred into the medium. This condition can only be applied to boundaries as the interface is only modeled mathematically.
RADIATION_SURFACE( " Lens-inner_Lens_Air"" ) {
type = radiation_interface
}RADIATION_SURFACE( "Lens-outer" ) {
external_emissivity_model = "my emissivity_model"
external_temperature = 313.0
}RADIATION_SURFACE( "Interface_fluid" ) {
diffused_fraction = 0.0
