EXX## Keyword §1 and number #1, option §2 and id #2, §1 clashes with #2This
            means strings §1 and §2 are incorrect and numbers #1 and #2 are incompatible. Changing
            §1 and #2 may resolve this issue.Error Code
When an error occurs, nanoFluidX will issue a corresponding code for that error. An error code starts with the letter E followed by a two-letter category identifier. For example, IO for input/output. The last element of the error code is a number representing the order within the category. For example, EIO 338.
Error Message
- §: This symbol represents a string such as a phase name or file path. These symbols are followed by a number according to their order in the message. A recurring § symbol will keep the same number.
 - #: This symbol represents a number such as a phase ID or motion ID. These symbols are followed by a number according to their order in the message. A recurring # symbol will keep the same number.
Error Description
This is an interpretation of the solver message. It may involve further explanation on why a certain situation occurs, the reason why the message has been issued, or the steps to take to alleviate the problem. It is meant as a first point of reference when a question on a certain message arises.
ECM - CELLMESH
ECM1
Cell number exceeds value range representable by ID type.
There are more cells in the computational domain than supported by the solver. Among others, this may be due to incorrect or incompatible input file export, min/max_domain, min/max_boundingbox, inputfile_factor, dx, r_c_dx or cutoff. In rare situations this error means the case is larger than what the solver supports.
ECM2
Resource limit in #1, #2 (#3,#4,#5) at (#6,#7,#8) in #9
This error suggests that considerable number of particles are concentrated in a certain region of the computational domain positioned about (#6,#7,#8). This error does not point to a specific cause for particle concentration and one should revisit the inputs to the solver. Among different reasons for this error are:
- particles clumping due to compression between moving walls
 - too large of a timestep size
 - too large of a single phase surface tension coefficient
 - incorrect motion definitions
 - unusual motion combinations
 - kernel dx in cfg doesn't match the actual dx in the discretized geometry
 - discretized geometric irregularities
 - hanging or overlapping particles
ECM3
Refer to previous description.
EDM - DOMAIN
EDM1
There are no motions, inlet regions or imposed regions to deduce a reference velocity. Please provide an explicit ref_vel in domain parameters section of the configuration file.
At least one motion, inlet region or imposed region definition is required to calculate the reference velocity "ref_vel" through fallback method. Providing an explicit reference velocity "ref_vel" would circumvent this error.
EDM2
The reference velocity "ref_vel" must be explicitly defined when a POSITION_FILE motion is present.
The solver has no fallback method for calculating the reference velocity of a "POSITION_FILE" type motion. Please provide a value for "ref_vel" keyword in "domain" section explicitly to recover from this error.
EDM3
The reference velocity "ref_vel" must be explicitly defined when a PASSIVE_RIGID_BODY motion is present.
The solver has no fallback method for calculating the reference velocity of a "PASSIVE_RIGID_BODY" type motion. Please provide a value for "ref_vel" keyword in "domain" section explicitly to recover from this error.
EDM4
Reference length "ref_length" must be explicitly specified when acceleration file ("bodyforce" file) is present.
The solver has no fallback method for calculating the reference length when a time-varying spatially uniform external acceleration field via "bodyforce" file is requested. Please provide a value for "ref_length" keyword in "domain" section explicitly to recover from this error.
EDM5
The simulation cannot start without a valid "domain" section.
The cfg file must contain a "domain" section. Please define one and assign appropriate values. Please ensure that there are no typographical mistakes and the cfg file has Linux line endings.
EDM6
The simulations should be either two- or three-dimensional.
The solver does not support one-dimensional simulations. Please set "ndim" to either 2 or 3.
EDM7
Input for"min_domain" and "max_domain" is inconsistent.
If specified manually, the domain size input for "min_domain" and "max_domain" must span a box, with max > min for all coordinate directions in the simulated dimensions. This warning may point to possible typographical errors in the cfg file.
EDM8
No Inputfile provided.
The field "inputfile" is missing or is not filled.
EDR - DYEREGIONS
EDR1
Dye color for dyeRegion #1 should be a positive integer.
Dye color "dyeregion_clr" must be a positive integer.
EFS - FRAMESUITE
EFS1
The "frame_obj_phase" is assigned to phase #1 which is larger than the total number of defined phases.
The requested phase number exceeds the number of phases defined in the "phases" section.
EFS2
The "frame_obj_phase" is not assigned to a phase.
There are no assigned phases or phase number is less than 1.
EFS3
The "frame_obj_phase" of a SLIDING frame is assigned to phase S1 which is not a MOVINGWALL.
The "frame_obj_phase" must be a MOVINGWALL phase for a SLIDING frame.
EFS4
The "frame_obj_phase" of a TEMPORAL frame is assigned to phase S1 which is not a WALL.
The "frame_obj_phase" must be a WALL phase for a TEMPORAL frame.
EFS5
The "frame_obj_phase" keyword of a SLIDING frame has not been defined.
The "frame_obj_phase" keyword is a mandatory input for a SLIDING frame.
EFS6
The "frame_road_phase" is assigned to phase #1 which is larger than the total number of defined phases.
EFS7
The "frame_road_phase" is not assigned to a phase.
EFS8
The "frame_road_phase" of a SLIDING frame is assigned to phase S1 which is not a MOVINGWALL.
The "frame_road_phase" must be a MOVINGWALL phase for a SLIDING frame.
EFS9
The "frame_road_phase" of a TEMPORAL frame is assigned to phase S1 which is not a WALL.
The "frame_road_phase" must be a WALL phase for a TEMPORAL frame.
EFS10
The "frame_road_phase" keyword has not been defined.
The "frame_road_phase" keyword is a mandatory input.
EFS11
The "frame_fluid_phase" is assigned to phase #1 which is larger than the total number of defined phases.
EFS12
The "frame_fluid_phase" is not assigned to a phase.
EFS13
The "frame_fluid_phase" is assigned to phase S1 which is not a FLUID.
The "frame_fluid_phase" must be a FLUID phase.
EFS14
The "frame_fluid_phase" keyword has not been defined.
The "frame_fluid_phase" keyword is a mandatory input.
EFS15
Invalid value for parameter "frame_lock_mode": #1.
The parameter "frame_lock_mode" can be set to values 0 (lock to line) or 1 (lock to point).
EFS16
Invalid value for parameter "frame_min_bc_overlay": "#1 #2 #3".
The parameter "frame_min_bc_overlay" is a three element predefined integer where each element represents the minimum boundary condition for each of the coordinate directions and can be set to values 0 (apply no additional layers), 1 (apply only freeze layers), 2 (apply only sponge layers) or 3 (apply freeze and sponge layers).
EFS17
Invalid value for parameter "frame_max_bc_overlay": "#1 #2 #3".
The parameter "frame_max_bc_overlay" is a three element predefined integer where each element represents the maximum boundary condition for each of the coordinate directions and can be set to values 0 (apply no additional layers), 1 (apply only freeze layers), 2 (apply only sponge layers) or 3 (apply freeze and sponge layers).
EFS18
Freeze layers have non-positive extension length.
If any freeze layer is applied by setting any component of "frame_min_bc_overlay" or "frame_max_bc_overlay" to 1 (only freeze) or 3 (freeze and sponge), the extension layer length obtained from either "frame_freeze_layer_length" or "frame_freeze_layer_lengthodx" must be positive.
EFS19
Sponge layers have non-positive extension length.
If any sponge layer is applied by setting any component of "frame_min_bc_overlay" or "frame_max_bc_overlay" to 2 (only sponge) or 3 (freeze and sponge), the extension layer length obtained from either "frame_sponge_layer_length" or "frame_sponge_layer_lengthodx" must be positive.
EFS20
Invalid value for parameter "frame_freezesponge_min_bc_clip": "#1 #2".
The parameter "frame_freezesponge_min_bc_clip" is a two element integer where the elements represent the minimum boundary condition in x- and y-direction, respectively. Each element can be set to values 0 (cover full domain height in z-direction), 1 (limit freeze and sponge layer based on "frame_fluid_clip_zcoord") or 2 (limit freeze and sponge layer based on "frame_freezesponge_min_bc_clip_zcoord").
EFS21
Invalid value for parameter "frame_freezesponge_max_bc_clip": "#1 #2".
The parameter "frame_freezesponge_max_bc_clip" is a two element integer where the elements represent the maximum boundary condition in x- and y-direction, respectively. Each element can be set to values 0 (cover full domain height in z-direction), 1 (limit freeze and sponge layer based on "frame_fluid_clip_zcoord") or 2 (limit freeze and sponge layer based on "frame_freezesponge_max_bc_clip_zcoord").
EFS22
Bounding box not defined in "domain" section of the cfg.
FrameSuite requires the bounding box to be defined in the "domain" section of the cfg via the parameters "min_boundingbox" and "max_boundingbox". When creating the case with SimLab, these parameters should be set automatically.
EFS23
Domain size not defined in "domain" section of the cfg.
FrameSuite requires the domain size to be defined in the "domain" section of the cfg via the parameters "min_domain" and "max_domain".
EFS24
Less than two points in the road path.
The road path must consist of at least two points.
EFS25
The road path must be strictly increasing in x coordinates.
EFS26
Less than two points in the road profile.
The road profile must consist of at least two points.
EFS27
The road profile must be strictly increasing in y coordinates.
EIM - IMPOSEREGIONS
EIM1
Magnitude of direction vector A for PARALLELEPIPEDVEL impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedvel_A_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM2
Length in A direction for PARALLELEPIPEDVEL impose region #1 must be non-negative.
The side length defined in "parallelepipedvel_A_len" is a negative number. The length must be zero or positive.
EIM3
Magnitude of direction vector B for PARALLELEPIPEDVEL impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedvel_B_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM4
Length in B direction for PARALLELEPIPEDVEL impose region #1 must be non-negative.
The side length defined in "parallelepipedvel_B_len" is a negative number. The length must be zero or positive.
EIM5
Magnitude of direction vector C for PARALLELEPIPEDVEL impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedvel_C_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM6
Length in C direction for PARALLELEPIPEDVEL impose region #1 must be non-negative.
The side length defined in "parallelepipedvel_C_len" is a negative number. The length must be zero or positive.
EIM7
Vectors A, B, and C defined for PARALLELEPIPEDVEL impose region #1 generate no volume, and will not have effect.
The vectors defining the parallelepiped are coplanar, so no volume is generated and the region will not have effect.
EIM8
The phase number requested for impose region #1 to move with is either non-positive or larger than the total number of phases.
The impose region motion phase "imposeregion_motphs" must be positive and no larger than the total number of phases defined in "phases" section.
EIM9
The phase requested for impose region #1 to move with is not a moving wall.
The impose region motion phase "imposeregion_motphs" must point to a MOVINGWALL phase from the "phases" section.
EIM10
Direction vector magnitude for a PARALLELEPIPEDVEL impose region is too small.
The magnitude of vector defined in "parallelepipedvel_unv" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM11
Axis vector magnitude for CYLINDERVEL impose region #1 is too small.
The magnitude of normal vector defined in "cylindervel_axis" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM12
The height of CYLINDERVEL impose region #1 must be non-negative.
The height of cylinder defined in "cylindervel_hght" is a negative number. The height must be zero or positive.
EIM13
The radius of CYLINDERVEL impose region #1 is negative.
The radius of a CYLINDERVEL impose region specified in "cylindervel_rad" must be non-negative.
EIM14
EIM15
EIM16
Velocity direction vector for CYLINDERDVEL impose region #1 is too small.
The magnitude of velocity direction vector defined in "cylindervel_unv" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM17
Magnitude of direction vector A for PARALLELEPIPEDACC impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedacc_A_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM18
Length in A direction for PARALLELEPIPEDACC impose region #1 must be non-negative.
The side length defined in "parallelepipedacc_A_len" is a negative number. The length must be zero or positive.
EIM19
Magnitude of direction vector B for PARALLELEPIPEDACC impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedacc_B_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM20
Length in B direction for PARALLELEPIPEDACC impose region #1 must be non-negative.
The side length defined in "parallelepipedacc_B_len" is a negative number. The length must be zero or positive.
EIM21
Magnitude of direction vector C for PARALLELEPIPEDACC impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedacc_C_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM22
Length in C direction for PARALLELEPIPEDACC impose region #1 must be non-negative.
The side length defined in "parallelepipedacc_C_len" is a negative number. The length must be zero or positive.
EIM23
Vectors A, B, and C defined for PARALLELEPIPEDACC impose region #1 generate no volume, and will not have effect.
EIM24
EIM25
EIM26
Direction vector magnitude for a PARALLELEPIPEDACC impose region is too small.
The magnitude of unit vector defined in "parallelepipedacc_unv" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM27
Normal vector magnitude for CYLINDERACC impose region #1 is too small.
The magnitude of vector defined in "cylinderacc_axis" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM28
The height of CYLINDERACC impose region #1 must be non-negative.
The height of cylinder defined in "cylinderacc_hght" is a negative number. The height must be zero or positive.
EIM29
The radius of CYLINDERACC impose region #1 must be non-negative.
The radius of a CYLINDERACC impose region specified in "cylinderacc_rad" is a negative number. The radius must be zero or positive.
EIM30
EIM31
EIM32
Direction vector magnitude for a CYLINDERACC impose region is too small.
The magnitude of vector defined in "cylinderacc_unv" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM33
Magnitude of direction vector A for PARALLELEPIPEDTEMP impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedtemp_A_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM34
Length in A direction for PARALLELEPIPEDTEMP impose region #1 must be non-negative.
The side length defined in "parallelepipedtemp_A_len" is a negative number. The length must be zero or positive.
EIM35
Magnitude of direction vector B for PARALLELEPIPEDTEMP impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedtemp_B_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM36
Length in B direction for PARALLELEPIPEDTEMP impose region #1 must be non-negative.
The side length defined in "parallelepipedtemp_B_len" is a negative number. The length must be zero or positive.
EIM37
Magnitude of direction vector C for PARALLELEPIPEDTEMP impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedtemp_C_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM38
Length in C direction for PARALLELEPIPEDTEMP impose region #1 must be non-negative.
The side length defined in "parallelepipedtemp_C_len" is a negative number. The length must be zero or positive.
EIM39
Vectors A, B, and C defined for PARALLELEPIPEDTEMP impose region #1 generate no volume, and will not have effect.
EIM40
EIM41
EIM42
Normal vector magnitude for CYLINDERTEMP impose region #1 is too small.
The magnitude of normal vector defined in "cylindertemp_axis" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM43
The height of CYLINDERTEMP impose region #1 must be non-negative.
The height of cylinder defined in "cylindertemp_hght" is a negative number. The height must be zero or positive.
EIM44
The radius of CYLINDERTEMP impose region #1 must be non-negative.
The radius of a CYLINDERTEMP impose region specified in "cylindertemp_rad" is a negative number. The radius must be zero or positive.
EIM45
EIM46
EIM47
Magnitude of direction vector A for PARALLELEPIPEDPOROUS impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedporous_A_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM48
Length in U direction for PARALLELEPIPEDPOROUS impose region #1 must be non-negative.
The side length defined in "parallelepipedporous_A_len" is a negative number. The length must be zero or positive.
EIM49
Magnitude of direction vector B for PARALLELEPIPEDPOROUS impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedporous_B_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM50
Length in B direction for PARALLELEPIPEDPOROUS impose region #1 must be non-negative.
The side length defined in "parallelepipedporous_B_len" is a negative number. The length must be zero or positive.
EIM51
Magnitude of direction vector C for PARALLELEPIPEDPOROUS impose region #1 is too small.
The magnitude of direction vector defined in "parallelepipedporous_C_vec" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM52
Length in C direction for PARALLELEPIPEDPOROUS impose region #1 must be non-negative.
The side length defined in "parallelepipedporous_C_len" is a negative number. The length must be zero or positive.
EIM53
Vectors A, B, and C defined for PARALLELEPIPEDPOROUS impose region #1 generate no volume, and will not have effect.
EIM54
EIM55
EIM56
At least two of the "porous_principal_ax_x_i", "porous_principal_ax_y_i" and "porous_principal_ax_z_i" for phase #1 should be defined.
If new axes of for the porous region were to be defined, at least two of the keywords "porous_principal_ax_x_i", "porous_principal_ax_y_i" or "porous_principal_ax_z_i" must appear in a PARALLELEPIPEDPOROUS Region definition. There is no need to define the principal axes if they are parallel to the global xyz axes. Typographical errors may also lead to this message.
EIM57
"porous_principal_ax_x_i" defined for region #1 has zero length.
The keyword "porous_principal_ax_x_i" of a PARALLELEPIPEDPOROUS motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EIM58
"porous_principal_ax_y_i" defined for region #1 has zero length.
The keyword "porous_principal_ax_y_i" of a PARALLELEPIPEDPOROUS motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EIM59
"porous_principal_ax_z_i" defined for region #1 has zero length.
The keyword "porous_principal_ax_z_i" of a PARALLELEPIPEDPOROUS motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EIM60
"porous_principal_ax_x_i" and "porous_principal_ax_y_i" defined for phase #1 are not perpendicular.
The dot product of vectors "porous_principal_ax_x_i" and "porous_principal_ax_y_i" of a PARALLELEPIPEDPOROUS motion is larger than 1.0e-6.
EIM61
"porous_principal_ax_x_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.
The dot product of vectors "porous_principal_ax_x_i" and "porous_principal_ax_z_i" of a PARALLELEPIPEDPOROUS motion is larger than 1.0e-6.
EIM62
"porous_principal_ax_y_i" and "porous_principal_ax_z_i" defined for region #1 are not perpendicular.
The dot product of vectors "porous_principal_ax_y_i" and "porous_principal_ax_z_i" of a PARALLELEPIPEDPOROUS motion is larger than 1.0e-6.
EIM63
"porous_principal_ax_x_i" and "porous_principal_ax_y_i" defined for region #1 are not perpendicular.
EIM64
EIM65
EIM66
"porous_principal_ax_x_i", "porous_principal_ax_y_i" and "porous_principal_ax_z_i" defined for region #1 do not follow the right hand rule.
The difference of the cross product of vectors "porous_principal_ax_x_i", "porous_principal_ax_y_i" and "porous_principal_ax_z_i" of a PARALLELEPIPEDPOROUS motion and 1 is larger than 1.0e-6.
EIM67
Normal vector magnitude for CYLINDERPOROUS impose region #1 is too small.
The magnitude of normal vector defined in "cylinderporous_axis" is smaller than 1.0e-6. This error may be due to missing keywords or typographical mistakes.
EIM68
The height of CYLINDERPOROUS impose region #1 must be non-negative.
The height of cylinder defined in "cylinderporous_hght" is a negative number. The height must be zero or positive.
EIM69
The radius of CYLINDERPOROUS impose region #1 must be non-negative.
The radius of a CYLINDERPOROUS impose region specified in "cylinderporous_rad" is a negative number. The radius must be zero or positive.
EIM70
EIM71
EIM72
If new axes of for the porous region were to be defined, at least two of the keywords "porous_principal_ax_x_i", "porous_principal_ax_y_i" or "porous_principal_ax_z_i" must appear in a CYLINDERPOROUS Region definition. There is no need to define the principal axes if they are parallel to the global xyz axes. Typographical errors may also lead to this message.
EIM73
The keyword "porous_principal_ax_x_i" of a CYLINDERPOROUS motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EIM74
The keyword "porous_principal_ax_y_i" of a CYLINDERPOROUS motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EIM75
The keyword "porous_principal_ax_z_i" of a CYLINDERPOROUS motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EIM76
The dot product of vectors "porous_principal_ax_x_i" and "porous_principal_ax_y_i" of a CYLINDERPOROUS motion is larger than 1.0e-6.
EIM77
The dot product of vectors "porous_principal_ax_x_i" and "porous_principal_ax_z_i" of a CYLINDERPOROUS motion is larger than 1.0e-6.
EIM78
The dot product of vectors "porous_principal_ax_y_i" and "porous_principal_ax_z_i" of a CYLINDERPOROUS motion is larger than 1.0e-6.
EIM79
EIM80
EIM81
EIM82
The difference of the cross product of vectors "porous_principal_ax_x_i", "porous_principal_ax_y_i" and "porous_principal_ax_z_i" of a CYLINDERPOROUS motion and 1 is larger than 1.0e-6.
EIR - INLETREGIONS
EIR1
Inlet region #1 has no phases associated with it.
An inlet region definition must include "inletregion_phase" keyword. This error may point to a typographical mistake.
EIR2
The phase number associated with inlet region #1 is either non-positive or larger than the total number of phases.
The inlet region phase "inletregion_phase" must be positive and no larger than the total number of phases defined in "phases" section.
EIR3
Inlet region #1 has to be associated with a fluid phase.
The inlet region phase "inletregion_phase" must point to a FLUID phases from the "phases" section.
EIR4
The phase number requested for inlet region #1 to move with is either non-positive or larger than the total number of phases.
The inlet region motion phase "inletregion_motphs" must be positive and no larger than the total number of phases defined in "phases" section.
EIR5
The phase requested for inlet region #1 to move with is not a moving wall.
The inlet region motion phase "inletregion_motphs" must point to a MOVINGWALL phase from the "phases" section.
EIR6
Inlet region #1 has non-positive extension length.
The extension length obtained from either "inletregion_extlen" or "inletregion_extlenodx" must be positive.
EIR7
Inlet region #1 has no normal vector specified.
An inlet region definition must include the keyword "inletregion_nrm". This error may point to a typographical mistake.
EIR8
Inlet region #1 has a zero length normal vector.
An inlet region must have a normal vector "inletregion_nrm" of non-zero magnitude.
EIR9
Inlet region #1 has a normal vector with more than one non-zero element. The normal vector may only point in positive or negative direction of the global coordinate system.
The normal vector of inlet regions of type "INREG_RECTANGULAR", "INREG_CIRCULAR" and "INREG_CUSTOM" must be aligned with global xyz axes. Please use "ARBOR" inlets for arbitrarily oriented inlet regions or change the normal "inletregion_nrm" to match the global xyz axes.
EIR10
Inlet region #1 has a zero length tangent vector.
An "INREG_RECTANGULAR_ARBOR" or "INREG_CIRCULAR_ARBOR" tangent vector "inletregion_tan" either is not defined or has zero magnitude.
EIR11
Inlet region #1 has a tangent that is not perpendicular to its normal vector.
The dot product of normal "inletregion_nrm" and tangent "inletregion_tan" vectors of an inlet region with arbitrary orientation is larger than 1.0e-3.
EIR12
Inlet region #1 has a non-fluid phase number in its "inletregion_stf_phaselist".
All phase numbers in the "inletregion_stf_phaselist" must point to a FLUID phase in the "phases" section.
EIR13
Inlet region #1 does not include its own phase in the given "inletregion_stf_phaselist".
The phase number in "inletregion_phase" must be included in the "inletregion_stf_phaselist".
EIR14
The stencil file S1 for inlet region #1 should have 3 or 4 columns.
An inlet region stencil file must have 3 columns for single-phase stencils and 4 columns for multi-phase stencils.
EIR15
The stencil file S1 for inlet region #1 has 4 columns. The option "inletregion_stf_phaselist" must be provided.
When using 4-column (multi-phase) stencils, it is mandatory to provide "inletregion_stf_phaselist".
EIR16
Please make sure to have #1 inlet regions using the stencil file S1, one for each phase.
When using 4-column (multi-phase) stencils, there must be a separate inlet region definition for each phase in the "inletregion_stf_phaselist". This error suggests that the number of inlet region definitions sharing the same stencil file is not equal to the number of phases in the "inletregion_stf_phaselist". It is assumed that "inletregion_stf_phaselist" does not contain repeating indices.
EIR17
Please make sure inlet regions using stencil file S1 have correct definition of their respective phases.
When using 4-column (multi-phase) stencils, there must be a separate inlet region definition for each phase in the "inletregion_stf_phaselist". This error suggests that there are repeating "inletregion_phase" values. It is assumed that "inletregion_stf_phaselist" does not contain repeating indices.
EIR18
The points in the stencil file provided for inlet region #1 are not planar.
The inlet region stencil must be planar. This solver raises this error when the average distance between inlet region's center and stencil points in the direction of inlet region normal is larger than 0.05dx. This error may point to an issue in exporting the stencil file.
EIR19
Inlet region #1 has negative radius.
The inlet region radius "inletregion_circle_rad" must be a non-negative number.
EIR20
EIR21
EIR22
The stencil file of inlet region #1 has less than two points. Please specify the tangent vector manually using "inletregion_tan" field.
It is not possible to compute a unique tangent vector from a single stencil point. At least two points are required to compute the tangent vector.
EIR23
Failed to compute tangent vector for inlet region #1. Please specify the tangent vector manually using "inletregion_tan" field.
The solver was not able to compute the tangent vector of the inlet region using the provided stencil points. This error may point to an issue within the stencil file. Specifying "inletregion_tan" in the cfg will circumvent this error message.
EIR24
The computed tangent vector for inlet region #1 is not perpendicular to the specified normal vector. Please specify the tangent vector manually using "inletregion_tan" field.
The dot product of the solver computed tangent vector of the inlet region with the cfg provided inlet region normal "inletregion_nrm" is greater than 1.0e-3. This may point to an issue with the stencil file or the provided normal vector. Specifying the "inletregion_tan" directly in the cfg will circumvent this error.
EIR25
EIR26
Inlet region #1 has at least one negative length.
All inlet region side lengths must be non-negative.
EIR27
EIR28
EIR29
EIR30
EIR31
EIR32
Inlet region #1 has a negative state. Please modify the normal to change the state direction.
Inlet region state value "inletregion_sttval" must be a non-negative number. Please modify inlet region normal "inletregion_nrm" direction to change state direction.
EIR33
Inlet region #1 has a state of type "vfl" or "mfl" with no valid stencil particles. Please specify a valid stencil file for "inletregion_stf_file" or use state type "vel".
Stencil particles must be provided through "inletregion_stf_file" to use volume flowrate (vfl) and mass flowrate (mfl) state options in "inletregion_stttyp" as the solver requires the number of particles in advance. The internally generated stencils are not acceptable in this mode.
EIR34
Inlet region #1 crosses the domain boundaries in at least one direction.
The inlet region's circular spawn surface is too close to a domain boundary (min/max_domain). Either increase the domain size or move the spawn surface away from the domain boundary.
EIR35
The inlet region's rectangular spawn surface is too close to a domain boundary (min/max_domain). Either increase the domain size or move the spawn surface away from the domain boundary.
EIR36
Inlet region #1 was not able to walk to a close mesh particle. Please modify the "inletregion_cnt" or disable "inletregion_meshmatch".
The solver has failed to find a point matching the initial Cartesian particle distribution to move the center of the inlet region to. To circumvent this error, disable the "inletregion_meshmatch" option and/or move the "inletregion_cnt" to a point that matches the initial Cartesian mesh more closely. Alternatively, you may use a stencil file.
EIO - INPUTOUTPUT
EIO1
Cannot find Casefile S1
The solver is not able to find the cfg file. Please check the path in your launch command.
EIO2
Found non-empty output data directory at S1 when "cleandir_opt" is set to BREAK.
The solver encountered a non-empty output data directory when "cleandir_opt" has been set to BREAK. Either remove the output data directory and run again or change "cleandir_opt" to MODIFY or PURGE. When set to MODIFY, the solver creates a new output data directory by appending simulation start time to the original output data directory name. When set to PURGE, the contents of the output data directory are removed.
EIO3
Failed to create case directory.
The solver encountered an issue while creating the case directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue.
EIO4
EIO5
EIO6
Failed to empty OUTPUT directory.
The solver failed to remove the contents of OUTPUT directory. The files may be in use by another process.
EIO7
Failed to empty PREVIEW directory.
The solver failed to remove the contents of PREVIEW directory. The files may be in use by another process.
EIO8
Failed to empty RECON directory.
The solver failed to remove the contents of RECON directory. The files may be in use by another process.
EIO9
Failed to empty LOG directory.
The solver failed to remove the contents of LOG directory. The files may be in use by another process.
EIO10
Failed to empty PHASEINFO directory.
The solver failed to remove the contents of PHASEINFO directory. The files may be in use by another process.
EIO11
Failed to empty PROBE directory.
The solver failed to remove the contents of PROBE directory. The files may be in use by another process.
EIO12
Failed to empty MOTION directory.
The solver failed to remove the contents of MOTION directory. The files may be in use by another process.
EIO13
Failed to empty STL directory.
The solver failed to remove the contents of UTM directory. The files may be in use by another process.
EIO14
The solver failed to remove the contents of STL directory. The files may be in use by another process.
EIO15
Failed to empty PVSTATE directory.
The solver failed to remove the contents of PVSTATE directory. The files may be in use by another process.
EIO16
Failed to empty EXTRACT directory.
The solver failed to remove the contents of EXTRACT directory. The files may be in use by another process.
EIO17
Failed to create OUTPUT directory.
The solver encountered an issue while creating the OUTPUT directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO18
Failed to create PREVIEW directory.
The solver encountered an issue while creating the PREVIEW directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO19
Failed to create RECON directory.
The solver encountered an issue while creating the RECON directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO20
Failed to create LOG directory.
The solver encountered an issue while creating the LOG directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO21
Failed to create PHASEINFO directory.
The solver encountered an issue while creating the PHASEINFO directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO22
Failed to create PROBE directory.
The solver encountered an issue while creating the PROBE directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO23
Failed to create MOTION directory.
The solver encountered an issue while creating the MOTION directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the correct filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO24
Failed to create UTM directory.
The solver encountered an issue while creating the UTM directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the correct filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO25
Failed to create STL directory.
The solver encountered an issue while creating the STL directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the correct filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO26
Failed to create PVSTATE directory.
The solver encountered an issue while creating the PVSTATE directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO27
Failed to create EXTRACT directory.
The solver encountered an issue while creating the EXTRACT directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO28
Failed to create output rank directories.
The solver encountered an issue while creating the rank# directory(ies) in OUTPUT directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue.
EIO29
Failed to create preview rank directories.
The solver encountered an issue while creating the rank# directory(ies) in PREVIEW directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue.
EIO30
Failed to create restart/continue rank directories.
The solver encountered an issue while creating the rank# directory(ies) in RECON directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue.
EIO31
Cannot find or failed to open input archive S1.
The solver is not able to find or open the input archive file. Please check the path in your launch command and make sure the archive file is accessible.
EIO32
Failed to open S1 of input archive S2.
The solver has encountered a problem when trying to access the contents of input archive file. The archive may be corrupt or inaccessible.
EIO33
Encountered an error while reading S1 of input archive S2.
The solver has encountered a problem while reading the contents of input archive file. The archive may be corrupt or inaccessible.
EIO34
Cannot find inputfile S1
The solver is not able to find/access the inputfile or copy the inputfile into "Used_inputfile.prtl". Please make sure both the inputfile and "Used_inputfile.prtl" are accessible to the solver.
EIO35
Cannot find Inputfile S1
The solver is not able to access the input file containing the discretized geometry. Either the file does not exist or the path is incorrect.
EIO36
Unexpected number of columns in the inputfile.
Each row of inputfile must contain 4 or 7 columns.
EIO37
EIO38
EIO39
Problem opening the bodyforce file
The solver is not able to find the acceleration field file specified for "bodyforce" in "domain" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO40
Empty line in bodyforce file S1
The solver encountered an empty line while reading the acceleration field from "bodyforce" in "domain" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO41
Problem reading the bodyforce file
The solver encountered a problem while reading the acceleration field from "bodyforce" in "domain" section. A likely reason is incorrect number of columns. Please make sure all rows have four columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO42
Problem opening the road path file S1.
The solver is not able to find the road path file specified for "frame_road_path_file_name" in "framesuite" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO43
Empty line in the road path file S1.
The solver encountered an empty line while reading the road path from "frame_road_path_file_name" in "framesuite" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO44
Problem reading the road path file S1.
The solver encountered a problem while reading the road path from "frame_road_path_file_name" in "framesuite" section. A likely reason is incorrect number of columns. Please make sure all rows have four columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO45
Problem opening the road profile file S1.
The solver is not able to find the road profile file specified for "frame_road_profile_file_name" in "framesuite" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO46
Empty line in the road profile file S1.
The solver encountered an empty line while reading the road profile from "frame_road_profile_file_name" in "framesuite" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO47
Problem reading the road profile file S1.
The solver encountered a problem while reading the road profile from "frame_road_profile_file_name" in "framesuite" section. A likely reason is incorrect number of columns. Please make sure all rows have four columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO48
Unable to access case directory S1
The solver encountered an issue while accessing the case directory during file system topology identification. The case directory having been deleted, being inaccessible or having other unknown file system issues may lead to this message.
EIO49
Root path S1 is not a directory.
The path to the case directory points to a file instead. The reason is unknown.
EIO50
Cannot write to case directory S1
The solver encountered an issue while writing to the case directory during file system topology identification. This may be due to inadequate permissions.
EIO51
Cannot read from case directory S1
The solver encountered an issue while reading from the case directory during file system topology identification. This may be due to inadequate permissions.
EIO52
Could not determine file system topology.
The solver was not able to determine the file system topology due to an unknown error. Please specify the file system topology explicitly through the cfg file.
EIO53
File system topology is ambiguous. Only one file system for all nodes or one file system per node is supported.
The solver was not able to determine the file system topology. This error indicates that there were no clear patterns of file system accessibility. Only one shared file system for all nodes or one local file system per node are supported. If your file system meets either of these criteria, please specify the file system topology explicitly through the cfg file.
EIO54
EIO55
Cannot find/open the time-velocity series file S1 for a PARALLELEPIPEDVEL impose region #1.
The solver is not able to find the time-velocity series file specified for "parallelepipedvel_tvs_file" in "imposeRegions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO56
Empty line in time-velocity series file S1 for a PARALLELEPIPEDVEL impose region #1.
The solver encountered an empty line while reading the time-velocity series from "parallelepipedvel_tvs_file" in "imposeRegions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO57
Encountered a problem while reading time-velocity series file S1 for PARALLELEPIPEDVEL impose region #1.
The solver encountered a problem while reading the time-velocity series from "parallelepipedvel_tvs_file" in "imposeRegions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO58
Cannot find/open the time-velocity series file S1 for CYLINDERVEL impose region #1.
The solver is not able to find the time-velocity series file specified for "cylindervel_tvs_file" in "imposeRegions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO59
Empty line in time-velocity series file S1 for CYLINDERVEL impose region #1.
The solver encountered an empty line while reading the time-velocity series from "cylindervel_tvs_file" in "imposeRegions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO60
Encountered a problem while reading time-velocity series file S1 for CYLINDERVEL impose region #1.
The solver encountered a problem while reading the time-velocity series from "cylindervel_tvs_file" in "imposeRegions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO61
Cannot find/open the time-acceleration series file S1 for a PARALLELEPIPEDACC impose region #1.
The solver is not able to find the time-acceleration series file specified for "parallelepipedacc_tas_file" in "imposeRegions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO62
Empty line in time-acceleration series file S1 for a PARALLELEPIPEDACC impose region #1.
The solver encountered an empty line while reading the time-acceleration series from "parallelepipedacc_tas_file" in "imposeRegions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO63
Encountered a problem while reading time-acceleration series file S1 for PARALLELEPIPEDACC impose region #1.
The solver encountered a problem while reading the time-acceleration series from "parallelepipedacc_tas_file" in "imposeRegions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO64
Cannot find/open the time-acceleration series file S1 for a CYLINDERACC impose region #1.
The solver is not able to find the time-acceleration series file specified for "cylinderacc_tas_file" in "imposeRegions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO65
Empty line in time-acceleration series file S1 for a CYLINDERACC impose region #1.
The solver encountered an empty line while reading the time-acceleration series from "cylinderacc_tas_file" in "imposeRegions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO66
Encountered a problem while reading time-acceleration series file S1 for CYLINDERACC impose region #1.
The solver encountered a problem while reading the time-acceleration series from "cylinderacc_tas_file" in "imposeRegions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO67
Cannot find/open the time-temperature series file S1 for a PARALLELEPIPEDTEMP impose region #1.
The solver is not able to find the time-temperature series file specified for "parallelepipedtemp_tts_file" in "imposeRegions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO68
Empty line in time-temperature series file S1 for a PARALLELEPIPEDTEMP impose region #1.
The solver encountered an empty line while reading the time-temperature series from "parallelepipedtemp_tts_file" in "imposeRegions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO69
Encountered a problem while reading time-temperature series file S1 for PARALLELEPIPEDTEMP impose region #1.
The solver encountered a problem while reading the time-temperature series from "parallelepipedtemp_tts_file" in "imposeRegions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO70
Cannot find/open the time-temperature series file S1 for a CYLINDERTEMP impose region #1.
The solver is not able to find the time-temperature series file specified for "cylindertemp_tts_file" in "imposeRegions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO71
Empty line in time-temperature series file S1 for a CYLINDERTEMP impose region #1.
The solver encountered an empty line while reading the time-temperature series from "cylindertemp_tts_file" in "imposeRegions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO72
Encountered a problem while reading time-temperature series file S1 for CYLINDERTEMP impose region #1.
The solver encountered a problem while reading the time-temperature series from "cylindertemp_tts_file" in "imposeRegions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO73
Cannot find/open the stencil file S1 for inlet region #1.
The solver is not able to find the inlet region stencil file specified for "inletregion_stf_file" in "inletregions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO74
Empty line in stencil file S1 for inlet region #1.
The solver encountered an empty line while reading the inlet region stencil from "inletregion_stf_file" in "inletreginos" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO75
Encountered a problem while reading stencil file S1 for inlet region #1.
The solver encountered a problem while reading the inlet reigon stencil from "inletregion_stf_file" in "inletreginos" section. A likely reason is incorrect number of columns. Please make sure all rows of single-phase stencil file have 3 columns and all rows of multi-phase stencil files have 4 columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO76
Not all phases mentioned in "inletregion_stf_phaselist" for inlet region #1 were found in file S1.
A 4-column (multi-phase) inlet region stencil files must include all phases mentioned in "inletregion_stf_phaselist".
EIO77
Encountered a negative state magnitude while reading time-state series file S1 for inlet region #1.
The solver encountered a negative number while reading the time-state series from "inletregion_tss_file" in "inletregions" section. All state magnitudes must be non-negative. Please change "inletregion_nrm" to change state direction.
EIO78
Cannot find/open the time-state series file S1 for inlet region #1.
The solver is not able to find the time-state series file specified for "inletregion_tss_file" in "inletregions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO79
Empty line in time-state series file S1 for inlet region #1.
The solver encountered an empty line while reading the time-state series from "inletregion_tss_file" in "inletregions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO80
Encountered a problem while reading time-state series file S1 for inlet region #1.
The solver encountered a problem while reading the time-state series from "inletregion_tss_file" in "inletregions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO81
Cannot find prescribed motion file S1
The solver is not able to find the prescribed motion file specified for "motion_type" in "motions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO82
Encountered an empty line while reading the header of prescribed motion file S1
The solver encountered an empty line while reading the header of the prescribed motion file. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO83
Encountered a problem while reading the header of prescribed motion file S1
The solver encountered a problem while reading the header of the prescribed motion file. A likely reason is the incorrect number of columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO84
Encountered an empty line while reading prescribed motion file S1
The solver encountered an empty line while reading the prescribed motion file. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO85
Encountered a problem while reading the prescribed motion file S1
The solver encountered a problem while reading the prescribed motion file. A likely reason is the incorrect number of columns. Please make sure that all lines have 8 columns for axis-angle mode (isOrientation true) and 7 columns for angular velocity mode (isOrientation false). The file should be in plain ASCII with Unix like line endings (LF).
EIO86
Cannot find/open the road path file S1 for motion #1.
The solver is not able to find the road path file specified for "dr1dof_rd_pth_file" in "motions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO87
Empty line in road path file S1 for motion #1.
The solver encountered an empty line while reading the road path from "dr1dof_rd_pth_file" in "motions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO88
Encountered a problem while reading road path file S1 for motion #1.
The solver encountered a problem while reading the road path from "dr1dof_rd_pth_file" in "motions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO89
Cannot find/open the preset time dependent linear velocity file (prbcon_linvel_f_c) S1 for passive rigid body motion #1.
The solver is not able to find the preset time dependent linear velocity file specified for "prbcon_linvel_f_c" in "motions" section for a passive rigid body. Please make sure the "prbcon_linvel_f_c" keyword is present, the specified file name/path is correct and the file pointed to exists.
EIO90
Empty line in preset time dependent linear velocity file (prbcon_linvel_f_c) S1 for passive rigid body motion #1.
The solver encountered an empty line while reading the preset time dependent linear velocity from "prbcon_linvel_f_c" in "motions" section for a passive rigid body. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO91
Encountered a problem while reading time dependent linear velocity file (prbcon_linvel_f_c) S1 for passive rigid body motion #1.
The solver encountered a problem while reading the time dependent linear velocity from "prbcon_linvel_f_c" in "motions" section for a passive rigid body. A likely reason is incorrect number of columns. Please make sure all rows have four columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO92
Cannot find/open the preset time dependent angular velocity file (prbcon_angvel_f_c) S1 for passive rigid body motion #1.
The solver is not able to find the preset time dependent angular velocity file specified for "prbcon_angvel_f_c" in "motions" section for a passive rigid body. Please make sure the "prbcon_angvel_f_c" keyword is present, the specified file name/path is correct and the file pointed to exists.
EIO93
Empty line in preset time dependent angular velocity file (prbcon_angvel_f_c) S1 for passive rigid body motion #1.
The solver encountered an empty line while reading the preset time dependent angular velocity from "prbcon_angvel_f_c" in "motions" section for a passive rigid body. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO94
Encountered a problem while reading time dependent angular velocity file (prbcon_angvel_f_c) S1 for passive rigid body motion #1.
The solver encountered a problem while reading the time dependent angular velocity from "prbcon_angvel_f_c" in "motions" section for a passive rigid body. A likely reason is incorrect number of columns. Please make sure all rows have four columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO95
Encountered a negative state magnitude while reading time-state series file S1 for outlet region #1.
The solver encountered a negative number while reading the velocity from time-state series file "outletregion_tss_file" in "outletregions" section. All velocity magnitudes must be non-negative. Please change "outletregion_nrm" to change velocity direction.
EIO96
Cannot find/open the time-state series file S1 for outlet region #1.
The solver is not able to find the time-state series file specified for "outletregion_tss_file" in "outletregions" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO97
Empty line in time-state series file S1 for outlet region #1.
The solver encountered an empty line while reading the time-state series from "outletregion_tss_file" in "outletregions" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO98
Encountered a problem while reading time-state series file S1 for outlet region #1.
The solver encountered a problem while reading the time-state series from "outletregion_tss_file" in "outletregions" section. A likely reason is incorrect number of columns. Please make sure all rows have two columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO99
The probe points file S1 specified for probe S2 contains less than two points.
A flowrate probe requires at least two points to function. This error may point to possible errors in probe points file specified for "probe_points_file" in "probes" section or typographical errors in the cfg file.
EIO100
Cannot find/open the probe points file S1 specified for probe S2.
The solver is not able to find the probe points file specified for "probe_points_file" in "probes" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO101
Empty line in the probe points file S1 specified for probe S2.
The solver encountered an empty line while reading the probe points from "probe_points_file" in "probes" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO102
Encountered a problem while reading the probe points file S1 specified for probe S2.
The solver encountered a problem while reading the probe points file from "probe_points_file" in "probes" section. A likely reason is incorrect number of columns. Please make sure all rows have three columns. The file should be in plain ASCII with Unix like line endings (LF).
EIO103
Bounding Box needs to be read from the restart/continue (recon) file.
A restart/continue (recon) run must use the bounding box values stored in the recon file.
EIO104
Encountered a problem while reading the inputfile (for BB).
This error suggests that there has been a problem in the input discretized geometry file. This may be due to wrong number of columns or empty lines in the file. The file should be in plain ASCII with Unix like line endings (LF). Exporting the discretized geometry again may resolve this problem.
EIO105
Domain Dimensions need to be read from the restart/continue (recon) file.
A restart/continue (recon) run must use the domain dimension values stored in the recon file.
EIO106
Could not determine the latest restart/continue (recon) file. Please use \"restart_from_step\" keyword to specify the timestep explicitly.
The solver was not able to determine the latest restart/continue (recon) file available. At least one recon file must be present. The error may be due to wrong "restart_from_dir", "output_data_dir" or a change in the cfg file name that leads the solver to search a directory without any recon files. The recon timesteps available for a specific simulation are listed in the "restart.txt" file.
EIO107
Unable to find restart/continue (recon) file S1
The solver is unable to find or access the restart/continue (recon) file. Please make sure the file exists. This may be due to typographical errors in defining "restart_from_dir" or "restart_from_step" keywords.
EIO108
Incompatible restart/continue (recon) file version (supplied/required): #1/#2
The restart/continue (recon) file version is not compatible with the solver version. The supplied recon file version and required recon file version by the solver are given in the error message.
EIO109
Encountered a problem while reading restart/continue (recon) file S1
The solver encountered a problem while reading a restart/continue (recon) file.
EIO110
EIO111
Problem opening the particle output times file S1
The solver is not able to find the particle output times file specified for "t_output_file" in "simulationParameters" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO112
Empty line in particle output times file S1
The solver encountered an empty line while reading the particle output times from "t_output_file" in "simulationParameters" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO113
Problem reading the particle output times file S1
The solver encountered a problem while reading the particle output times from "t_output_file" in "simulationParameters" section. Please make sure the file contains exactly one number per line. The file should be in plain ASCII with Unix like line endings (LF).
EIO114
Problem opening the restart output times file S1
The solver is not able to find the restart output times file specified for "t_output_restart_file" in "simulationParameters" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO115
Empty line in restart output times file S1
The solver encountered an empty line while reading the restart output times from "t_output_restart_file" in "simulationParameters" section. Please remove the empty line from the file and try again. The file should be in plain ASCII with Unix like line endings (LF).
EIO116
Problem reading the restart output times file S1
The solver encountered a problem while reading the restart output times from "t_output_restart_file" in "simulationParameters" section. Please make sure the file contains exactly one number per line. The file should be in plain ASCII with Unix like line endings (LF).
EIO117
Cannot find/open the stl file S1 for extractor S2.
The solver is not able to find the stl file specified for "extractor_stlfile" in "extractors" section. Please make sure the file exists and/or the path to the file in cfg is correct.
EIO118
Encountered a problem while reading the input geometry file.
EIO119
Encountered a problem with the (restart/continue) recon file (nonexistent or unreadable) S1
The solver is not able to access a restart/continue (recon) file. The file may not exist or the path is incorrect. Please make sure the chosen timestep to restart/continue the simulation from corresponds to an available recon file.
EIO120
The solver is not able to read a restart/continue (recon) file. The file may be corrupt or in an incorrect format.
EIO121
Failed to create EXTRACT sub directory for vtp output of extractor S1.
The solver encountered an issue while creating a subdirectory under EXTRACT directory. The path may not be accessible. Retrying the simulation or changing the case path may resolve this issue. If this happens in a multi-node run, the filesystem topology might not have been determined correctly. In this case, the filesystem topology can be set manually by setting the parameter "filesys_topo" in "simulationParameters" to SHARED if all nodes share the same output filesystem or DISTRIBUTED if every node writes to a separate filesystem.
EIO122
Failed to create EXTRACT sub directory for synchronized output S1.
EIO123
Failed to create EXTRACT sub directory for txt output of extractor S1.
EIO124
Failed to create EXTRACT sub directory for info output of extractor S1.
EIO125
Failed to create EXTRACT sub directory for synchronized info output of extractor S1.
EIO126
Encountered a problem while opening stl file S1 for extractor S2.
The solver encountered a problem while opening the stl file specified for "extractor_stlfile" in "extractors" section. The file name or path may be wrong or the file may not exist, lack required permissions, be corrupt or be inaccessible due to other reasons.
EIO127
Encountered a problem while reading stl file S1 for extractor S2.
The solver encountered a problem while reading the stl file from "extractor_stlfile" in "extractors" section. The file may be corrupt, contain ill formated data, have become inaccessible during the read operation or be unreadable due to other reasons.
EKR - KERNEL
EKR1
The simulation cannot start without a valid "kernel" section.
The cfg file must contain a "kernel" section. Please define one and assign appropriate values. Please ensure that there are no typographical mistakes and the cfg file has Linux line endings.
EKR2
Either `dx' or `cutoff' need to be specified in the configuration file.
Either "dx" or "cutoff" must be defined and have a positive value.
EMT - MOTIONS
EMT1
Invalid "max_dist" is specified for motion #1 applied to phase #2.
The maximum distance "max_dist" of a "ROTATE", "ROTATE_AXIS" or "PLANETARY" motion must be a positive number. It is mandatory to define "max_dist" of a motion of aforementioned types when no explicit definition of "ref_vel" is given in "domain" section. This error may be due to missing keywords or typographical mistakes.
EMT2
EMT3
EMT4
Motion #1 is assigned to phases #2 and #3, where at least one is larger than the total number of defined phases.
At least one of the requested phase numbers for a "CONROD" motion exceeds the number of phases defined in the "phases" section.
EMT5
Motion #1 is assigned to phases #2 and #3, where at least one phase is not a MOVINGWALL.
At least one phase in a "CONROD" motion definition points to a non-MOVINGWALL phase.
EMT6
CONROD motion #1 has no phase_piston and/or phase_conrod assigned.
A "CONROD" motion is missing the definition of at least one of "phase_piston" or "phase_conrod". Typographical errors or setting the aforementioned keywords to a number less than 1 may also lead to this message.
EMT7
Motion #1 is assigned to phase #2 which is larger than the total number of defined phases.
The requested phase number exceeds the number of phases defined in the "phases" section.
EMT8
At least one motion is defined but not assigned to a phase.
There are no phases assigned to this motion or phase number is less than 1.
EMT9
Motion #1 is assigned to phase S1 which is not a WALL or a MOVINGWALL.
An "IMPOSE_VEL" or "ROTATE_AXIS" motion is assigned to a non-WALL or non-MOVINGWALL phase.
EMT10
Motion #1 is assigned to phase S1 which is not a MOVINGWALL.
A motion is assigned to a non-MOVINGWALL phase
EMT11
"rot_freq" of motion #1 not defined or with zero magnitude.
The keyword "rot_freq" of a "ROTATE" motion is either not defined or has a small magnitude. Typographical errors may also lead to this message.
EMT12
"rot_axis" of motion #1 not defined or with zero magnitude.
The keyword "rot_axis" of a "ROTATE_AXIS" motion is either not defined or has a small magnitude. Typographical errors may also lead to this message.
EMT13
"conrod_axis" of motion #1 not defined or with zero magnitude.
The keyword "conrod_axis" of a "CONROD" motion is either not defined or has a small magnitude. Typographical errors may also lead to this message.
EMT14
"crankshaft_normal" of motion #1 not defined or with zero magnitude.
The keyword "crankshaft_normal" of a "conrod_axis" motion is either not defined or has a small magnitude. Typographical errors may also lead to this message.
EMT15
No prescribed motion file specified in the configuration file of motion #1
The "motion_type" keyword for a "POSITION_FILE" motion is either not specified or has no value. Typographical errors may also lead to this message.
EMT16
Body motion #1 is assigned to phase #2 which is larger than the total number of defined phases or less than 1.
At least one requested body phase number exceeds the number of phases defined in the "phases" section or is less than 1.
EMT17
Front wheel Motion #1 is assigned to phase #2 which is larger than the total number of defined phases or less than 1.
At least one requested front wheel phase number exceeds the number of phases defined in the "phases" section or is less than 1.
EMT18
Rear wheel Motion #1 is assigned to phase #2 which is larger than the total number of defined phases or less than 1.
At least one requested rear wheel phase number exceeds the number of phases defined in the "phases" section or is less than 1.
EMT19
Motion #1 has phase #2 assigned to both body and front wheels.
The same phase number appears in both body and front wheel phase lists.
EMT20
Motion #1 has phase #2 assigned to both body and rear wheels.
The same phase number appears in both body and rear wheel phase lists.
EMT21
Motion #1 has phase #2 assigned to both front and rear wheels.
The same phase number appears in both front wheel and rear wheel phase lists.
EMT22
Motion #1 supports "reardrive" and "frontdrive" options only.
Driver modes for a double roller motion are "reardrive" and "frontdrive". Please note that the options may be written in any combination of lowercase and uppercase letters.
EMT23
Motion #1 is missing forward axis point definition.
In a double roller motion, the forward axis point must always be defined.
EMT24
Motion #1 is missing rear axis point definition.
In a double roller motion, the rear axis point must always be defined.
EMT25
Coordinate x of the front wheel is less than or equal to that of the rear wheel in motion #1.
In a double roller motion, the x coordinate of the front wheel must be larger than that of the rear wheel.
EMT26
Motion #1 is missing wheel radius definition.
In a double roller motion, the wheel radius must always be defined.
EMT27
Wheel radius of Motion #1 is not positive.
In a double roller motion, the wheel radius must be a positive number.
EMT28
Arc segment length coefficient of motion #1 is missing wheel radius definition.
In a double roller motion, the arc segment length coefficient must be a positive number.
EMT29
Road path file of motion #1 has less than two points.
At least two points (one road segment) must be specified in the road path file of a double roller motion.
EMT30
The x coordinate values (first column) of the road path file of motion #1 must be strictly increasing.
In a double roller motion, the x coordinate values of the road path must be strictly increasing. This means that each x value must be greater than the x values of the previous lines.
EMT31
A piece of the road path file of motion #1 has zero length.
This means that there are repeating lines (x and z values) in the road path file of a double roller motion.
EMT32
The length of at least one piece of road of a pair with a topside angle of less than 180 degrees is too short along the other piece's normal to be projected on the elevated road. Please either increase the length of the road piece along the normal of the connecting piece or reduce the wheel radius. This error is likely to occur on small bumps along the road. You may also remove these bumps to avoid this error.
EMT33
At least two consecutive pieces of the road path file of motion #1 have the same slope.
The consecutive road pieces of a double roller motion must have unique normals. Please merge the consecutive road pieces with the same slope to avoid this error.
EMT34
A piece of the elevated road of motion #1 has zero length.
A piece of the elevated road of a double roller motion has a length of zero.
EMT35
The initial position of wheel axes of motion #1 must lie within the first road piece.
The initial center of both wheel axes of a double roller motion must lie within the first road piece when projected onto the road tangent.
EMT36
At least two of the mom_principal_ax_x_i, mom_principal_ax_y_i and mom_principal_ax_z_i for phase #1 should be defined.
If principal axes of moment of inertia were to be defined, at least two of the keywords "mom_principal_ax_x_i", "mom_principal_ax_y_i" or "mom_principal_ax_z_i" must appear in a "PASSIVE_RIGID_BODY" motion's definition. There is no need to define the principal axes if they are parallel to the global xyz axes. Typographical errors may also lead to this message.
EMT37
mom_principal_ax_x_i defined for phase #1 has zero length.
The keyword "mom_principal_ax_x_i" of a "PASSIVE_RIGID_BODY" motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EMT38
mom_principal_ax_y_i defined for phase #1 has zero length.
The keyword "mom_principal_ax_y_i" of a "PASSIVE_RIGID_BODY" motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EMT39
mom_principal_ax_z_i defined for phase #1 has zero length.
The keyword "mom_principal_ax_z_i" of a "PASSIVE_RIGID_BODY" motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EMT40
mom_principal_ax_x_i and mom_principal_ax_y_i defined for phase #1 are not perpendicular.
The dot product of vectors "mom_principal_ax_x_i" and "mom_principal_ax_y_i" of a "PASSIVE_RIGID_BODY" motion is larger than 1.0e-6.
EMT41
mom_principal_ax_x_i and mom_principal_ax_z_i defined for phase #1 are not perpendicular.
The dot product of vectors "mom_principal_ax_x_i" and "mom_principal_ax_z_i" of a "PASSIVE_RIGID_BODY" motion is larger than 1.0e-6.
EMT42
mom_principal_ax_y_i and mom_principal_ax_z_i defined for phase #1 are not perpendicular.
The dot product of vectors "mom_principal_ax_y_i" and "mom_principal_ax_z_i" of a "PASSIVE_RIGID_BODY" motion is larger than 1.0e-6.
EMT43
EMT44
EMT45
EMT46
mom_principal_ax_x_i, mom_principal_ax_y_i and mom_principal_ax_z_i defined for phase #1 do not follow the right hand rule.
The difference of the cross product of vectors "mom_principal_ax_x_i", "mom_principal_ax_y_i" and "mom_principal_ax_z_i" of a "PASSIVE_RIGID_BODY" motion and 1 is larger that 1.0e-6.
EMT47
At least two of the prbcon_ax_x_i, prbcon_ax_y_i and prbcon_ax_z_i for phase #1 should be defined.
At least two of the vectors "prbcon_ax_x_i", "prbcon_ax_y_i" and "prbcon_ax_z_i" of a "PASSIVE_RIGID_BODY" motion are required to determine the third vector.
EMT48
prbcon_ax_x_i defined for phase #1 has zero length.
The keyword "prbcon_ax_x_i" of a "PASSIVE_RIGID_BODY" motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EMT49
prbcon_ax_y_i defined for phase #1 has zero length.
The keyword "prbcon_ax_y_i" of a "PASSIVE_RIGID_BODY" motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EMT50
prbcon_ax_z_i defined for phase #1 has zero length.
The keyword "prbcon_ax_z_i" of a "PASSIVE_RIGID_BODY" motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EMT51
prbcon_ax_x_i and prbcon_ax_y_i defined for phase #1 are not perpendicular.
The dot product of vectors "prbcon_ax_x_i" and "prbcon_ax_y_i" of a "PASSIVE_RIGID_BODY" motion is larger than 1.0e-6.
EMT52
prbcon_ax_x_i and prbcon_ax_z_i defined for phase #1 are not perpendicular.
The dot product of vectors "prbcon_ax_x_i" and "prbcon_ax_z_i" of a "PASSIVE_RIGID_BODY" motion is larger than 1.0e-6.
EMT53
prbcon_ax_y_i and prbcon_ax_z_i defined for phase #1 are not perpendicular.
The dot product of vectors "prbcon_ax_y_i" and "prbcon_ax_z_i" of a "PASSIVE_RIGID_BODY" motion is larger than 1.0e-6.
EMT54
EMT55
EMT56
EMT57
prbcon_ax_x_i, prbcon_ax_y_i and prbcon_ax_z_i defined for phase #1 do not follow the right hand rule.
The difference of the cross product of vectors "prbcon_ax_x_i", "prbcon_ax_y_i" and "prbcon_ax_z_i" of a "PASSIVE_RIGID_BODY" motion and 1 is larger that 1.0e-6.
EMT58
At most one element of prbcon_ax_hinge_c defined for phase #1 may be set to 1.
Only one element of "prbcon_ax_hinge_c" of a "PASSIVE_RIGID_BODY" motion may be equal to 1 to denote the hinge axis. Setting all elements to zero means a ball and socket joint. Remove or comment the keyword to disable hinge/joint.
EMT59
"year_rotVector" must have a nonzero magnitude.
The keyword "year_rotVector" of a "PLANETARY" motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EMT60
"day_rotVector' must have a nonzero magnitude.
The keyword "day_rotVector" of a "PLANETARY" motion is either not defined or has zero magnitude. Typographical errors may also lead to this message.
EMT61
Invalid frequency unit ("freq_unit") for a non-"PASSIVE_RIGID_BODY" motion: S1. Options are "Hz", "RPM", "Rad/s" and "Rad/min" (default: "Hz")
The input for "freq_unit" of a non-"PASSIVE_RIGID_BODY" motion does not represent a valid unit. Typographical errors may also lead to this message.
EMT62
Invalid frequency unit ("freq_unit") for a "PASSIVE_RIGID_BODY" motion: S1. Options are "Hz", "RPM", "Rad/s" and "Rad/min" (default: "Rad/s")
The input for "freq_unit" of a "PASSIVE_RIGID_BODY" motion does not represent a valid unit. Typographical errors may also lead to this message.
EOR - OUTLETREGIONS
EOR1
A phase number associated with outlet region #1 is either non-positive or larger than the total number of phases.
All phase numbers must be greater than zero and less than the number of phases defined in "phases" section.
EOR2
An invalid extension type is requested for outlet region #1. Please use setacc, setvel or noext.
Recognized extension types are "noext", "setacc" and "setvel". The type names are not case sensitive. This error may point to a typographical mistake.
EOR3
Outlet region #1 has non-positive extension length.
Outlet region extension length ("outletregion_extlen" or "outletregion_extlenodx") must be a non-negative number.
EOR4
Outlet region #1 has a zero length normal vector.
The solver has detected a zero length outlet region normal "outletregion_nrm". This may be due to missing keyword or typographical mistakes.
EOR5
Outlet region #1 has a normal vector with more than one non-zero element. The normal vector may only point in positive or negative direction of the global coordinate system.
Outlet region normal "outletregion_nrm" must be parallel to the global x, y or z axis.
EOR6
Outlet region #1 has no normal vector specified.
The solver was not able to find the "outletregion_nrm" keyword in the cfg file. This may be due to missing keyword or typographical mistakes.
EOR7
EOR8
EOR9
EOR10
EOR11
EOR12
Sphere outlet region #1 has no radius specified.
The solver was not able to find the "outletregion_sphere_rad" keyword in the cfg file. This may be due to missing keyword or typographical mistakes.
EOR13
Sphere outlet region #1 has non-positive radius.
Outlet region radius "outletregion_sphere_rad" must be a positive number.
EOR14
Cuboid outlet region #1 has no length specified.
The solver was not able to find the "outletregion_cuboid_len" keyword in the cfg file. This may be due to missing keyword or typographical mistakes.
EOR15
Cuboid outlet region #1 has at least one non-positive length value.
All outlet region side lengths "outletregion_cuboid_len" must be positive numbers.
EOR16
Cylinder outlet region #1 has no radius specified.
The solver was not able to find the "outletregion_cylinder_rad" keyword in the cfg file. This may be due to missing keyword or typographical mistakes.
EOR17
Cylinder outlet region #1 has non-positive radius.
Outlet region radius "outletregion_cylinder_rad" must be a positive number.
EOR18
Cylinder outlet region #1 has no height specified.
The solver was not able to find the "outletregion_cylinder_hgt" keyword in the cfg file. This may be due to missing keyword or typographical mistakes.
EOR19
Cylinder outlet region #1 has non-positive height.
Outlet region height "outletregion_cylinder_hgt" must be a positive number.
EOR20
Outlet region #1 has negative state. Please modify the normal to change state direction.
Outlet region state magnitude "outletregion_extstt" of a "setvel" type extension must be a non-negative number. Please modify outlet region normal "outletregion_nrm" direction to change velocity direction.
EPH - PHASES
EPH1
Number of phases bigger than maximum allowed (#1).
The maximum number of phases is limited to 100. Please note that each subphase group (WALL and MOVINGWALL) counts as one phase.
EPH2
The simulation cannot start without a valid "phases" section.
The cfg file must contain a "phases" section. Please define one and assign appropriate values. Please ensure that there are no typographical mistakes and the cfg file has Linux line endings.
EPH3
The contact angle requested for phase #1 has an invalid value: #2.";
Contact angle needs to be a value between 0 and 180 degrees.
EPH4
Phase #1, requested for calculating fluid contact time of solid phase #2, is larger than the total number of phases, #3.
The requested fluid contact phase number "fluidContactPhase" exceeds the number of phases defined in the "phases" section.
EPH5
The fluid contact time is requested for phase #1 which is not a WALL or MOVINGWALL.
Fluid contact time is only available for WALL or MOVINGWALL phases. In other words, "fluidContactPhase" keyword is restricted to WALL and MOVINGWALL phase types.
EPH6
The non-fluid phase #1 is assigned for calculating fluid contact time of solid phase #2.
The solver measures the contact time of FLUID phases with WALL or MOVINGWALL phases only. In other words, the value of "fluidContactPhase" keyword must point to a FLUID phase.
EPH7
Subphase option is not supported with energy transport in non-isothermal solids.
Sub phasing feature is not available when energy transport is active and wall or movingwall phases have evolving temperature fields. Please either set "evolve_temp" to false or set "makesubphase" to false.
EPR - PROBES
EPR1
Probe number #1 of type S1 requires at least one fluid phase definition. There is no fluid phase present in the cfg.
Probe types "volumeprobe", "surfaceprobe" and "flowrateprobe" require at least one FLUID phase definition in the cfg. Please remove the probes from the cfg or add a FLUID phase to the cfg to proceed.
EPR2
Unknown probe type S1 for probe number #1.
Only "volumeprobe", "surfaceprobe", "solidprobe" and "flowrateprobe" are recognized probe types. Typographical errors may lead to this messsage.
EPR3
No normal vector has been specified for probe S1.
A probe requiring a normal vector is missing "probe_nrmvec" in its definition.
EPR4
The normal vector specified for probe S1 has zero magnitude.
A probe requiring a normal vector "probe_nrmvec" has a zero magnitude vector in its definition.
EPR5
EPR6
EPR7
The parallel vector specified for probe S1 has zero magnitude.
A probe requiring a parallel vector "probe_tanvec" has a zero magnitude vector in its definition.
EPR8
Parallel and normal vectors specified for probe S1 are not sufficiently perpendicular.
The dot product of parallel and normal vectors defined for a flowrate probe is larger than 1.0e-3.
EPR9
Probe S1 is attached to phase number #1, which is greater than the total number of phases at #2.
The requested phase number in "probe_phase" exceeds the number of phases defined in the "phases" section.
EPR10
Probe S1 is attached to phase number #1, which is not a moving wall.
The requested phase number "probe_phase" for a "volumeprobe", "surfaceprobe" or "flowrateprobe" movement does not point to a MOVINGWALL in "phases" section.
EPR11
Probe S1 is attached to phase number #1, which is not a wall or a moving wall.
The requested phase number "probe_phase" for a "solidprobe" points neither to a WALL nor a MOVINGWALL in "phases" section.
EPR12
Probe S1 is not attached to a phase. Solid probes must attach to a wall or a moving wall to sample from.
A "solidprobe" must have a defined "probe_phase" pointing to WALL or MOVINGWALL phase in the "phases" section.
EPR13
Failed to compute parallel vector for probe S1. Please specify the parallel vector manually using "probe_tanvec" field.
The solver was not able to compute the parallel vector of a flowrate probe using the probe points. This error may point to an issue within the probe file. Specifying "probe_tanvec" in the cfg will circumvent this error message.
EPR14
The computed parallel vector for probe S1 is not perpendicular to the specified normal vector. Please specify the parallel vector manually using "probe_tanvec" field.
The parallel vector of a flowrate probe computed by the solver is not perpendicular to the probe normal "probe_nrmvec" specified in the cfg (dot product greater than 1.0e-3). This may point to possible issues with probe points file. Specifying the "probe_tanvec" directly in the cfg will circumvent this error.
ERT - RUNTIME
ERT1
Failed allocating 'h_localcell_owner' on Host
This error points to a likely issue with host memory (RAM).
ERT2
Failed allocating 'd_localcell_owner' on GPU
This error points to a likely issue with GPU memory.
ERT3
Failed allocating 'h_localcell_gID' on Host
ERT4
Failed allocating 'd_localcell_gID' on GPU
ERT5
Failed allocating 'h_remotecell_gID' on Host
ERT6
Failed allocating 'h_remotecell_lID' on Host
ERT7
Failed allocating 'h_remotecell_owner' on Host
ERT8
Failed allocating '_clist->at(i).pic' on GPU
ERT9
Failed allocating '_clist->at(i).beginIdx' on GPU
ERT10
Failed allocating '_clist->at(i).endIdx' on GPU
ERT11
Failed allocating '_clist->at(i).picYZLayer' on GPU
ERT12
Failed allocating 'd_localcell_weights' on GPU
ERT13
Failed allocating 'h_localcell_weights' on Host
ERT14
Failed reset 'd_localcell_weights' on GPU
ERT15
Failed downloading 'd_localcell_weights' from GPU
ERT16
Encountered a problem while loading inletregion stencils on GPU
ERT17
Encountered a problem while resizing prtl arrays on GPU in S1
ERT18
Encountered a problem while resizing prtl buffers on GPU in S1
ERT19
Encountered a problem while freeing prtl buffers on GPU in S1
ERT20
Encountered a problem while resizing ghost arrays on GPU in S1
ERT21
Encountered a problem while freeing ghost arrays on GPU in S1
ERT22
Failed getting `pos' on GPU
ERT23
Failed getting `vel' on GPU
ERT24
Failed getting `prop.rho' on GPU
ERT25
Failed getting `prop.temp' on GPU
ERT26
Failed getting `prop.vol_frac' on GPU
ERT27
Failed getting `attr' on GPU
ERT28
Failed getting `gradc' on GPU
ERT29
Failed getting `curv_den' on GPU
ERT30
Failed getting `vcorr' on GPU
ERT31
Failed getting `wall normals' on GPU
ERT32
Failed getting `relpos' on GPU
ERT33
Failed getting `subphase' on GPU
ERT34
Failed getting `dyecolor' on GPU
ERT35
Failed getting `fluidContact' on GPU
ERT36
Failed getting `pos' from GPU
ERT37
Failed getting `vel' from GPU
ERT38
Failed getting `acc' from GPU
ERT39
Failed getting `gradc' from GPU
ERT40
Failed getting `gradc2' from GPU
ERT41
Failed getting `vcorr' from GPU
ERT42
Failed getting `prop' from GPU
ERT43
Failed getting `prop.temp' from GPU
ERT44
Failed getting `prop.visctemp' from GPU
ERT45
Failed getting `prop.vol_frac' from GPU
ERT46
Failed getting `attr' from GPU
ERT47
Failed getting `wall' from GPU
ERT48
Failed getting `moving wall' from GPU
ERT49
Failed getting `subphase' from GPU
ERT50
Failed getting `dyecolor' from GPU
ERT51
Failed getting `fluidContact' from GPU
ESP - SIMPARAM
ESP1
Invalid input for keyword chain S1.S2: S3. Valid options are: S4
An unrecognized value S3 for the parameter represented by the keyword chain has been provided in the cfg file. The keyword chain is formatted as key1.key2, where key1 is the highest level keyword and and key2 the parameter name. The list S4 shows the accepted inputs for that option.
ESP2
Missing input for keyword chain S1.S2. Valid options are: S3
The parameter represented by the keyword chain requires explicit input by the user, but none has been provided in the cfg file. The keyword chain is formatted as key1.key2, where key1 is the highest level keyword and and key2 the parameter name. The list S3 shows the accepted inputs for that option.
ESP3
Invalid input for keyword chain S1.S2(#1).S3: S4. Valid options are: S5
An unrecognized value S4 for the parameter represented by the keyword chain has been provided in the cfg file. The keyword chain is formatted as key1.key2(#).key3, where key1 is the highest level keyword, key2 is the second level keyword and key3 is the parameter name. The second level key is accompanied by a number in parentheses pointing to the order in second level keyword list. The list S5 shows the accepted inputs for that option.
ESP4
Missing input for keyword chain S1.S2(#1).S3. Valid options are: S4
The parameter represented by the keyword chain requires explicit input by the user, but none has been provided in the cfg file. The keyword chain is formatted as key1.key2(#).key3, where key1 is the highest level keyword, key2 is the second level keyword and key3 is the parameter name. The second level key is accompanied by a number in parentheses pointing to the order in second level keyword list. The list S4 shows the accepted inputs for that option.
ESP5
Missing input for keyword chain S1.S2. The boundary conditions for each of the cordinate directions can be chosen from: S3
The parameter represented by the keyword chain requires explicit input by the user, but none has been provided in the cfg file. The keyword chain is formatted as key1.key2, where key1 is the highest level keyword and and key2 the parameter name. The input for each of the coordinate directions can be chosen from the values shown in the list S3.
ESP6
Missing input for keyword chain S1.S2(#1).S3. The boundary conditions for each of the cordinate directions can be chosen from: S4
The parameter represented by the keyword chain requires explicit input by the user, but none has been provided in the cfg file. The keyword chain is formatted as key1.key2(#1).key3, where key1 is the highest level keyword, key2 is the second level keyword and key3 is the parameter name. The second level key is accompanied by a number in parentheses pointing to the order in second level keyword list. The input for each of the coordinate directions can be chosen from the values shown in the list S4.
ESP7
DESIGN operation mode is only available for single fluid phase. For cases with more than one fluid, please use NORMAL or CONSERVATIVE operation modes.
When setting "operationMode" to "DESIGN", only one phase in the "phases" section may be of FLUID type.
ESP8
More than two FLUID phases detected. The ADAMI surface tension model is not supported for more than two FLUID phases.
The surface tension model "ADAMI" only supports two FLUID phases.
ESP9
More than two FLUID phases detected. The TARTAKOVSKY2016_F1 surface tension model is not supported for more than two FLUID phases.
The surface tension model "TARTAKOVSKY2016_F1" only supports two FLUID phases.
ESP10
The simulation cannot start without a valid "simulationParameters" section.
The cfg file must contain a "simulationParameters" section. Please define one and assign appropriate values. Please ensure that there are no typographical mistakes and the cfg file has Linux line endings.
ESP11
Log output frequency "freq_log" has to be a positive integer value.
The log output frequency "freq_log" is the number of timesteps between log outputs and has to be a positive integer value.
ESP12
APD attenuation interval "APD_attenuation_interval" has equal start and end points.
APD attenuation interval start and end points must be different. Please use different values. For a sharp cut at the starting value, set the end value to a number smaller than the starting one.
ESP13
It is not possible to activate "viscTempCoupling" without enabling "energy_transport".
Energy transport must be activated when using temperature viscosity coupling. This means if "viscTempCoupling" is set to true, "energy_transport" must be set to true as well.
ESP14
"aeroViscMode" and "viscTempCoupling" may not be enabled simultaneously. Please choose only one.
The solver supports either aeration viscosity or temperature dependent viscosity. If "viscTempCoupling" is set to true, "aeroViscMode" may only be set to "NOMODE". If "aeroViscMode" is set to "LOCAL" or "GLOBAL", the value of the keyword "viscTempCoupling" must be false.
ESP15
The value of "restart_from_step" keyword is less than -1. The starting step of a restart/continue (recon) run must be a non-negative integer.
A restart/continue (recon) run may only start with a non-negative step number. Please set "restart_from_step" keyword's value to a non-negative integer. You may also comment out the keyword-value pair or set "restart_from_step" to -1 to use the latest available recon file.
ESP16
Output file write interval has to be defined either through "dt_output" or through "t_output_file" for "output_type" other than NOOUTPUT.
If particle output is requested ("output_type" set to anything other than "NOOUPUT"), output times must be defined either through a positive value for output interval "dt_output" or through a file "t_output_file" containing a list of output times.
ESP17
Time step size factor "dt_factor" must be a positive number.
Time step size factor "dt_factor" must be a positive number. Set "dt_factor" to 1 or remove it from cfg to deactivate.
ESP18
The specified restart/continue (recon) time is greater than the end time of the simulation.
The current simulation end time "t_end" is smaller than the time stored in the recon file. Please make sure that "t_end" is greater than the simulation time when the requested recon file was saved.
ESP19
Too many GPU-devices requested. Currently limited to #1 GPUs
The solver supports up to 4096 GPU devices.
ESE - SURFEXTS
ESE1
The phase number requested for extractor S1 to move with is either non-positive or larger than the total number of phases.
The extractor motion phase "extractor_motphs" must be positive and no larger than the total number of phases defined in "phases" section.
ESE2
The phase requested for extractor S1 to move with is not a moving wall.
The extractor motion phase "extractor_motphs" must point to a MOVINGWALL phase from the "phases" section.
ESE3
Non-reset HTC is requested for extractor S1 without activating energy transport. Please activate "energy_transport" in "simulationParameters" section.
Calculation of non-reset heat transfer coefficient on extractor faces requires solving energy equation to evolve temperature. As a result, "energy_transport" option in "simulationParameters" section must be turned on.
ESE4
Both non-reset and reset HTC are requested for extractor S1. Please activate only one option.
Calculation of reset and non-reset heat transfer coefficient on extractor faces are mutually exclusive. Only one of the options, instantaneous or periodically time averaged, may be active at any give time. For example, "extractor_output_htc_rpee_i" and "extractor_output_htc_nrpee_pta" may not be set to true simultaneously for a given simulation.
ESE5
Both non-reset and reset HTC are requested across at least two different extractors. Please activate only one option across all extractors.
EVS - VISCTEMP
EVS1
It is not possible to enable temperature-viscosity coupling and have energy transport switch set to false.
The keyword "energy_transport" in "simulationParameters" must be set to true to use temperature dependent viscosity. Please either activate energy transport or disable temperature-dependent viscosity to proceed.
