Experimental Validation - DSD Case
Experimental Setup
The rotation speed is changed from 500 to 3000 RPM in increments of 500 RPM. The oil level is varied from 40 to 80 mm, measuring from the axis of the gear.
Numerical Setup
The initial particle arrangement is obtained by directly discretizing the CAD model provided by DSD without any simplification. This results in approximately 8.6 million particles (dx = 1e-3 m) for oil and air phases combined.
Results
