Launch a Simulation via PBS Access
- Browse to your PBS Access server and login.
- Click the Jobs menu and select Submit Job > nanoFluidX
- Select the nanoFluidX version to be used and enter a Job name.
Select (or drag-and-drop) the input files to the browser so that they are
uploaded.
Note: It is possible to upload a *.zip file when there are many files or if the file size is large. This will be automatically extracted at runtime.
- Select the number of GPUs to use and click Submit job.
