Expert Parameters
Additional expert parameters can be used to fine-tune simulations.
When these parameters are not specified, established default values are applied and the expert parameters do not appear in the effective solver deck written by the solver.
When you specify values for the expert parameters, they are used instead of the default values. The parameters are also included in the effective solver deck written to disk by ultraFluidX.
