Simulation Parameters
Available parameters for defining simulations in ultraFluidX.
ultraFluidX Solver Input Deck
<uFX_solver_deck name="ultraFluidX" xmlns="https://www.altair.com/ultrafluidx/”
which is parent to all other elements in the file, so the file must always end with </uFX_solver_deck> according to XML standards.
All categories and parameters must be specified in this way. The category or parameter, for example, always begins with a command of the format <example> and ends with the corresponding command </example>, with the respective child entries or the parameter specification in between.
The ultraFluidX solver input deck is grouped into five main categories: <simulation>, <meshing>, <boundary_conditions>, <sources> and <output>, each of them with several sub-categories and possible parameters as described below.
An example case (roadster.xml, roadster.stl) using the most important features including <rotating>, <belt>, <porous> and <probe_file> is located in the installation folder uFX/examples/roadster/.
