HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using
the HgTrans GUI or via the HgTrans batch mode.
The HWTK GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HWTK GUI Toolkit commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
An edit field containing a number, with up and down errors on the right-hand side, which allows the user to increase/decrease
the number by a given increment.
Contains one or more frames, separated by horizontal and/or vertical dividers. The dividers can be repositioned by
clicking on them and dragging the mouse.
The Model Identification Tool (MIT) is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The MIT operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble
HyperWorks automations with minimal effort and maximum portability.
hwtk::sizegrip
Allows the user to resize the containing top level window by pressing and dragging the grip. Also known as a grow box.
hwtk::spinbox
An edit field containing a number, with up and down errors on the right-hand side, which allows the user to increase/decrease the number by a given increment.
hwtk::splitframe
Contains one or more frames, separated by horizontal and/or vertical dividers. The dividers can be repositioned by clicking on them and dragging the mouse.
hwtk::statebutton
Widget containing buttons with an accompanying image which will update based on the selection, to show the state of the widget.
