HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using
the HgTrans GUI or via the HgTrans batch mode.
The HWTK GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HWTK GUI Toolkit commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
Opens an anonymous editor dialog to return a user-specified color. This function halts execution of the current thread
until the editor is dismissed or a color is picked.
A hwtk::inputdialog implements a modal dialog to ask user for a value. It displays a label and/or image, and an editor
based on input type. Will return the value when OK is pressed.
The Model Identification Tool (MIT) is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The MIT operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble
HyperWorks automations with minimal effort and maximum portability.
hwtk::chooseentitycolor
Opens an anonymous editor dialog to return a user-specified color. This function halts execution of the current thread until the editor is dismissed or a color is picked.
hwtk::inputdialog
A hwtk::inputdialog implements a modal dialog to ask user for a value. It displays a label and/or image, and an editor based on input type. Will return the value when OK is pressed.
