Connectors
New Features
- Added apply mass controller to replace the apply mass panel.
Enhancements
- Metal Clip Enhancements
- Added an option for determining the hole nodes.
 - Added an option to offset the cylindrical selection horizontally.
 - Stitch HL Enhancements
- Stitch HL can now have more than two links.
 - Node selection is available during absorption for Stitch HL.
 - HAZ size is now dependent on the plate thickness.
 - Stitch HL can now be split.
 - Other Enhancements
- Miscellaneous enhancements to CWELD and CFAST realizations.
 - Absorb now supports elements and nodes as link types.
 - Absorb correctly assigns element type for core configs that support changing the element type.
 - RBE3 Connect tool retains the selection.
 - Rebuild option is now set as default in various configs for the "After Imprint" and "Unrealize Remesh or Rebuild" attributes.
 - xMCF now supports Weld Database file support
 - Connector control file auto-loaded from the Absorb GUIs as well
 - MAT8 and PSHELL for Huth/Rutman Formulation is now calculated as a Composite.
 - CFAST Element System is now available for Huth realization.
Resolved Issues
- Fixed an issue where some blind drill holes were not recognized.
 - Fixed issues regarding crashes when realizing or absorbing connectors.
 - Resolved issue with PSOLID as the first link on a connector.
