Morphing
Enhancements
- Panel Migration to Controllers
 - is migrated under the Morph pull-down menu.
 - Panel Migration to Context
- Convert Forces to Shapes function is added as Create from Loads in the Shapes context menu. Access by right-clicking in the Edit Shapes dialog.
 - Autoshape function is added in the Shapes context menu. Access by right-clicking in the Edit Shapes dialog.
 - Smooth shapes function is added as Check/Smooth in the Shapes context menu. Access by right-clicking on shapes in the Edit Shapes dialog.
