Altair HyperWorks
Altair HyperWorks
2023
  1. Home
  2. Altair HyperWorks Tools
    Administrative tools to customize your Altair HyperWorks installation.
  3. Model Identification Tool
    The Model Identification Tool (MIT) is a profile in HyperGraph for fitting test data from frequency- and amplitude-dependent bushings to analytical models. The MIT operates in conjunction with HyperGraph, MotionView and MotionSolve to provide you with a comprehensive solution for modeling and analysis.
  4. Use the Altair Bushing Model with MotionSolve
    This section provides information about using the Altair Bushing Model, also known as AutoBushFD, with MotionSolve.
  5. Theory and Formulations
  6. Damping Force Models
    The Altair Bushing Model includes the following Damping Force Models:
  7. Rubber Damping Model
  • What's New
  • Altair HyperWorks Introduction
  • Tutorials
  • Altair HyperWorks Tools
Index
Altair HyperWorks
Altair HyperWorks
  • What's New
    Quick introduction to Altair HyperWorks products.
  • Tutorials
    Discover the functionality of Altair HyperWorks products with interactive tutorials.
    • Altair License Utility
      The Altair License Utility is a tool allowing you to determine a host ID, check license usage, borrow licenses, and set up hosted Altair Units.
    • Altair Compute Console
      Altair Compute Console (ACC) is a utility that allows you to start different Altair HyperWorks Solvers.
    • Remote Job Submission
      Remote Job Submission in Altair Compute Console (ACC) is implemented as an alternative to a local run.
    • Remote Server User Guide
    • AbaqusODB Upgrade
      AbaqusODB UpGrade is a HyperView tool, which upgrades ODB files created in Abaqus 2018 (or earlier) to Abaqus 2023.
    • HgTrans
      HgTrans translates solver results files from their native file format to Altair Binary Format (ABF). This can be done using the HgTrans GUI or via the HgTrans batch mode.
    • HvTrans
      HvTrans is a result translator for HyperView that translates solver result files to .h3d files.
    • HWTK GUI Toolkit
      The HWTK GUI Toolkit is a resource tool for coding Tcl/Tk dialogs. It contains documentation of the HWTK GUI Toolkit commands, demo pages that illustrate our Altair GUI standards, and sample code for creating those examples.
    • Cleanup Utility
      The Cleanup Utility is a script for Windows that removes any custom settings that you may have due to the Altair applications installed.
    • Model Identification Tool
      • MIT and the Fitting Process
      • Start MIT
        This section explains how to start the MIT interactively and in batch mode.
      • Use MIT
        This section explains how to use the features in HWTK GUI Toolkit.
      • Appendix I: SPD File Format Specification
      • Altair Bushing Model
        The Altair Bushing Model is a library of sophisticated, frequency- and amplitude-dependent bushing models that you can use for accurate vehicle dynamics, durability and NVH simulations. The Altair Bushing Model supports both rubber bushings and hydromounts.
      • Use the Altair Bushing Model with MotionView
        This section provides information about using the Altair Bushing Model, also known as AutoBushFD, with MotionView. The Altair Bushing Model is a sophisticated model that you can use to simulate the behavior of bushings in vehicle dynamics, durability and NVH simulations.
      • Use the Altair Bushing Model with MotionSolve
        • Features of the Altair Bushing Model
        • Select Force Models in the Bushing Property File
        • Theory and Formulations
          • Stiffness Force Models
            The Altair Bushing Model includes Stiffness Force Models for Spline Stiffness, Constant Stiffness and Cubic Stiffness:
          • Damping Force Models
            • Constant Damping Model
            • Rubber Damping Model
              • Schematic and Equations
              • First Order Filter
              • Scale Factors P0, P1, P2, and Q0, Q1, Q2
              • Multiple Preloads
              • Factor RMIN
              • Select a Lower Bound of R and Rmin
            • Hydromount Damping Model
          • Friction Formulation
            This section provides information about the LuGre and Dahl formulations for friction.
          • Mount Stiffness
            The bodies connected by the bushing are flexible and may deflect under the load being transmitted. This phenomenon is modeled with the Mount Stiffness feature. Mount stiffness models the structural stiffness of the bodies, thus mounting the bushing as a linear spring and damper in series with the bushing in each direction.
          • Mount Limits
            The Altair Bushing Model includes a Mount Limits feature, which lets you model the material contact that occurs between the bodies that a bushing connects. The bodies are flexible and may deflect under the load being transmitted. Given enough bushing deflection, the bodies may contact one another for negative and positive deflections in each direction.
          • Preload, Offset, and Scale
            This section describes how preloads, offsets and scales enter into bushing force computations. You use Preloads, Offsets and Scales to alter the operating point of a bushing. You can offset the bushing displacement in any direction, and scale the input displacement and velocity. You can also offset the bushing force in any direction by adding a preload or scale-output force or moment in any direction.
          • Coupling
            Coupling refers to the forces and moments generated in a bushing to oppose the overall deformation of the bushing. These forces and moments are independent of any coordinate system that might be used to measure the deformation or deformation velocity. Coupling is an important factor when the bushing characteristics are non-linear.
          • Validate Test Data in the SPD File
            The System Performance Data file, *.spd, contains the test data used for fitting a bushing. This data should be validated to ensure that it is physically meaningful. One test for physical consistency is that the dynamic stiffness at any amplitude of vibration must always be greater than the static stiffness at the same amplitude.
        • Bushing Property File
        • Mount Limits Property File
        • References
      • Supported Solvers
    • Register HVPcontrol
      Register HVPcontrol registers the HVP ActiveX control for HyperView Player.
    • HyperWorks Automation Toolkit
      The HyperWorks Automation Toolkit (HWAT) is a collection of functions and widgets that allows an application to quickly assemble HyperWorks automations with minimal effort and maximum portability.
    • H3D Validation Tools
      The H3D Validation Tools available are H3D Info and H3D Validate.
    • Uninstall
      Use the Altair HyperWorks Products Uninstaller to remove all files from the installation directory.
Altair HyperWorks
Altair HyperWorks
2023
  1. Home
  2. ...
  3. Rubber Damping Model
  • What's New
  • Tutorials
Index
ON THIS PAGE
    • Multiple Preloads
    • Factor RMIN
    ON THIS PAGE
