Post-processing utility that uses results from CFD simulations to generate a PowerPoint report containing images,
animations, and graphs of the results from the simulation.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Automate simulation processes with templates and utility scripts.
Template Manager
Use the Template Manager to define rule-based logic for groups, geometric operations, and setup and automate simulation processes.
Python API
Use python based automation to quickly setup HyperMesh CFD for ultraFluidX simulations in batch mode.
hwCFDReport
Post-processing utility that uses results from CFD simulations to generate a PowerPoint report containing images, animations, and graphs of the results from the simulation.
