User Interface
Explore the user interface.
- Menu BarThe menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help.
- RibbonsThe ribbon allows you to quickly access tools and standard functions, and is located along the top of the user interface. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
- Results BrowserThe Results Browser allows you to view the model structure while providing find, display, and editing control of entities.
- Entity EditorUse the Entity Editor section of the Results Browser to view and edit various entity conditions/properties.
- Entity SelectorUse the entity selector to specify which type of entity you are able to select.
- Modeling WindowThe modeling window is where your model is displayed.
- View ControlsView controls enable you to control the view and display of your model in the modeling window.
- Status BarThe status bar displays information pertaining to the currently loaded model.
- Animation
              ToolbarView your model in motion using animation controls.
