Supported File Formats
File formats supported.
Format Extension
Recovery File .strec
Template .xml
SN (Uniaxial and Multiaxial)
Format Extension
OptiStruct .h3d
.h5
Radioss
Note: Radioss result files can imported via the Hyper3D format.
.h3d
Nastran .op2
.h5
Abaqus .odb
ANSYS .rst
LS-DYNA
Note: Supported only for elemental evaluation.
.d3plot
EN (Uniaxial and Multiaxial)
Format Extension
OptiStruct .h3d
.h5
Radioss
.h3d
Nastran .op2
.h5
Abaqus .odb
ANSYS .rst
LS-DYNA
.d3plot
Dang van FOS
Format Extension
OptiStruct .h3d
.h5
Radioss
.h3d
Nastran .op2
.h5
Abaqus .odb
ANSYS .rst
LS-DYNA
.d3plot
Seam Weld
Format Extension
Grid Point Forces from OptiStruct .h3d
Grid Point Forces from Nastran .op2
Spot Weld
Format Extension
Direct Element Forces from OptiStruct .h3d
Direct Element Forces from Nastran .op2
Note: Support will be extended to further solver results in upcoming builds.
Transient Fatigue Analysis (SN, EN)
Format Extension
OptiStruct .h3d
Radioss
.h3d
Nastran .op2
.h5
Abaqus .odb
ANSYS .rst
LS-DYNA
.d3plot
Modal Superposition
Table 1. Modal Stress
Format Extension
OptiStruct .h3d
Nastran .op2
Table 2. Modal Participation Factors
Format Extension
OptiStruct .pch
MotionSolve .mrf
Nastran .pch
Random Response Fatigue with PSD Stresses
Format Extension
OptiStruct
.h3d
Random Response Fatigue with Frequency Response Analysis and PSD Loading
Format Extension
OptiStruct .h3d
Nastran .op2
.h5
Abaqus .odb
ANSYS
.rst
Sine Sweep Fatigue
Format Extension
OptiStruct .h3d
Nastran .op2
.h5
Abaqus .odb
ANSYS
.rst
