In order to import sets in any format, you must first load
a model.
Click the Sets tool.
From the Set panel, select a set/group.
Click Export.
The Export Sets dialog is displayed.
Select a file type (HyperView set definition file,
Patran session file, Nastran set file, or OptiStruct set file) from the Select
format drop-down menu.
Under File name, click the open folder icon and select a destination
folder.
Enter a file name and click Save.
Optional: Activate the Export selected sets option to export only
selected sets in the panel.
Click OK in the Export Sets dialog.
The exported file is saved as a text file.
Note: When exporting, HyperLife will
automatically export the ID ranges contained in the set instead of writing
out the individual IDs.
This file can then be imported, by clicking
Import in the Set panel.
