The Weld Evaluation
There are six types of welds that are supported by HL-WC.
| Weld Type | Illustration |
| T - Welds | ![]()  |
| L - Welds | ![]()  |
| Butt Welds | ![]()  |
| Overlap Welds | ![]()
| Cross (X) Welds | ![]()  |
| Multiple (M) Welds | ![]()  |
Some Considerations for Weld Evaluations
- For T and L welds, the coordinate system of the 1D beam element is oriented in such a way that the Y axis of the coordinate system points to Location 1 of the weld and the Z axis of the coordinate system points to Location 3 of the weld element.
 - For all the supported weld types, the X axis of the 1D beam coordinate system is oriented along with weld direction.
 - You need to check and modify the classification parameters for all the welds to be evaluated.
