Find and Search for Entities
The search bar can be used to find and filter entities in a browser.
Perform a Quick Search
Perform an Advanced Search Using Auto-Completion
Interactively build search strings using a dynamic suggestion list.
- Press the Down Arrow key to scroll thought the list of attributes, operators, or values.
 - Press Tab or Enter to select the attributes, operators, or values
 - Press Esc to dismiss the list of attributes, operators, or values.
 - While searching for text with space or special characters, use quotes (“ ”).
 - To search multiple values with a single attribute entry, use a coma after the first value selection without a space.
 - Double-click on an attributes, operators, or values to invoke suggestion list.
Access Recent Search Strings
Figure 4.
Clicking on a recent search string auto-applies the filter and shows the search string in the search bar.
